[Qgis-user] poligonal entity copied from a layer to another appears in the table, not in the view
Alessio Degioannini a.degioannini at proterstudio.com
Sat Dec 20 02:22:45 PST 2014
Hi Nicolas,
> Try copying the content of the second file to an empty file to see
> what happens.  If that works, try copying the content of the first
> file in that new file and see what happens.
Nothing.... Same issue: new record ok, no new entity in view.
> Could it be a projection problem?  Look to see if both files are in
> the same projection.  I usually use cut and paste between two file
> with the same CRS.
Every layer is in the same projection.
Every layer is polygonal.
Weird a lot!
Thank you,
Alessio
Il 19/12/2014 15:06, Nicolas Cadieux ha scritto:
> Hi,
> Sounds weird.  Try copying the content of the second file to an empty
> file to see what happens.  If that works, try copying the content of
> the first file in that new file and see what happens.
> with the same CRS.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> Le 2014-12-19 04:49, "Alessio Degioannini [via OSGeo.org] " <[hidden
> email] </user/SendEmail.jtp?type=node&node=5178555&i=0>> a écrit :
>     Hi,
>     I've just copied an entity from a poligonal layer to another.
>     No geometry or topology error in the source layer, no geo/top
>     errror in
>     the target layer before pasting the new entity.
>     After pasting: in the target layer table appears the espected new
>     record, in the view: nothing. No reply to zoom to selected command.
>     Check geometry freezes. Check topology ok.
>     Help me, please.
>     Thanks in advance.
>     Alessio
>     _______________________________________________
>     Qgis-user mailing list
>     [hidden email] </user/SendEmail.jtp?type=node&node=5178522&i=0>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
>     If you reply to this email, your message will be added to the
>     discussion below:
>     http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522.html
>     To start a new topic under Quantum GIS - User, email [hidden
>     email] </user/SendEmail.jtp?type=node&node=5178555&i=1>
>     To unsubscribe from Quantum GIS - User, click here.
>     NAML
>     <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: poligonal entity copied from a layer
> <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178555.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141220/5baeef8e/attachment.html>
