[Qgis-user] poligonal entity copied from a layer to another appears in the table, not in the view
Joris Hintjens jorishin at gmail.com
Sat Dec 20 05:20:50 PST 2014
Hi Nicolas,
 I have had same issues. In my case the problem was that the target layer had styling properties. The new added elements had no style and appeared blank. My advise; check the styling in the layer properties.
Greets
Joris
> Op 20-dec.-2014, om 11:22 heeft Alessio Degioannini <a.degioannini at proterstudio.com> het volgende geschreven:
> Hi Nicolas,
>> Try copying the content of the second file to an empty file to see what happens.  If that works, try copying the content of the first file in that new file and see what happens.
> Nothing.... Same issue: new record ok, no new entity in view.
>> Could it be a projection problem?  Look to see if both files are in the same projection.  I usually use cut and paste between two file with the same CRS.
> Every layer is in the same projection.
> Every layer is polygonal.
> Weird a lot!
> Thank you,
> Alessio
> Il 19/12/2014 15:06, Nicolas Cadieux ha scritto:
>> Hi,
>> Sounds weird.  Try copying the content of the second file to an empty file to see what happens.  If that works, try copying the content of the first file in that new file and see what happens.
>> Nicolas Cadieux M.Sc.
>> Les Entreprises Archéotec inc.
>> 8548, rue Saint-Denis Montréal H2P 2H2
>> Téléphone: 514.381.5112  Fax: 514.381.4995
>> Le 2014-12-19 04:49, "Alessio Degioannini [via OSGeo.org] " <[hidden email] <x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=0>> a écrit :
>> Hi,
>> I've just copied an entity from a poligonal layer to another.
>> No geometry or topology error in the source layer, no geo/top errror in
>> the target layer before pasting the new entity.
>> After pasting: in the target layer table appears the espected new
>> record, in the view: nothing. No reply to zoom to selected command.
>> Check geometry freezes. Check topology ok.
>> Help me, please.
>> Thanks in advance.
>> Alessio
>> Qgis-user mailing list
>> [hidden email] <x-msg://3/user/SendEmail.jtp?type=node&node=5178522&i=0>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>> If you reply to this email, your message will be added to the discussion below:
>> http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522.html <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522.html>
>> To start a new topic under Quantum GIS - User, email [hidden email] <x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=1>
>> To unsubscribe from Quantum GIS - User, click here <applewebdata://58BF44E9-B80F-43AA-9897-5357DC0DC3FF>.
>> NAML <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: poligonal entity copied from a layer to another appears in the table, not in the view <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178555.html>
>> Sent from the Quantum GIS - User mailing list archive <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at Nabble.com.
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141220/95f4ca47/attachment.html>
