[Qgis-user] poligonal entity copied from a layer to another appears in the table, not in the view
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Dec 20 08:32:35 PST 2014
Yes that could be it...  Sometime simple is better... But if he did a cut in paste in an empty file, then the file should not have styling properties....
Alessio, check out to make sure its not a styling issue an send me the files if you can.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2014-12-20 08:21, "Joris Hintjens [via OSGeo.org]" <ml-node+s1560n5178669h0 at n6.nabble.com> a écrit :
	Hi Nicolas,  I have had same issues. In my case the problem was that the target layer had styling properties. The new added elements had no style and appeared blank. My advise; check the styling in the layer properties. Greets Joris   Op 20-dec.-2014, om 11:22 heeft Alessio Degioannini < [hidden email] > het volgende geschreven: Hi Nicolas, Try copying the content of the second file to an empty file to see what happens.  If that works, try copying the content of the first file in that new file and see what happens. Nothing.... Same issue: new record ok, no new entity in view. Could it be a projection problem?  Look to see if both files are in the same projection.  I usually use cut and paste between two file with the same CRS.   Every layer is in the same projection. Every layer is polygonal. Weird a lot! Thank you, Alessio Il 19/12/2014 15:06, Nicolas Cadieux ha scritto: <blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' cite="mid:7b2652e5-e112-43f1-bd16-d2e2e4a6491b at HUCCAS02P.hostedmsx.local" type="cite" style="font-family: Helvetica; font-size: 12px; font-style: normal; font-variant: normal; font-weight: normal; letter-spacing: normal; line-height: normal; orphans: auto; text-align: start; text-indent: 0px; text-transform: none; white-space: normal; widows: auto; word-spacing: 0px; -webkit-text-stroke-width: 0px; background-color: rgb(255, 255, 255);" class=""> Hi, Sounds weird.  Try copying the content of the second file to an empty file to see what happens.  If that works, try copying the content of the first file in that new file and see what happens. Could it be a projection problem?  Look to see if both files are in the same projection.  I usually use cut and paste between two file with the same CRS.   Nicolas Cadieux M.Sc. Les Entreprises Archéotec inc.  8548, rue Saint-Denis Montréal H2P 2H2 Téléphone: 514.381.5112  Fax: 514.381.4995 Le 2014-12-19 04:49, "Alessio Degioannini [via OSGeo.org ] " <<a moz-do-not-send="true" href="x-msg://3/user/SendEmail.jtp?type=node&amp;node=5178555&amp;i=0" target="_top" rel="nofollow" link="external" class="">[hidden email] > a écrit : <blockquote style='border-left:2px solid #CCCCCC;padding:0 1em' class="quote" style="border-left-width: 2px; border-left-style: solid; border-left-color: rgb(204, 204, 204); padding: 0px 1em;">Hi,  I've just copied an entity from a poligonal layer to another.  No geometry or topology error in the source layer, no geo/top errror in  the target layer before pasting the new entity.  After pasting: in the target layer table appears the espected new  record, in the view: nothing. No reply to zoom to selected command.  Check geometry freezes. Check topology ok.  Help me, please.  Thanks in advance.  Alessio  _______________________________________________  Qgis-user mailing list  <a moz-do-not-send="true" href="x-msg://3/user/SendEmail.jtp?type=node&amp;node=5178522&amp;i=0" target="_top" rel="nofollow" link="external" class="">[hidden email]   http://lists.osgeo.org/mailman/listinfo/qgis-user If you reply to this email, your message will be added to the discussion below: http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522.html To start a new topic under Quantum GIS - User, email <a moz-do-not-send="true" href="x-msg://3/user/SendEmail.jtp?type=node&amp;node=5178555&amp;i=1" target="_top" rel="nofollow" link="external" class="">[hidden email]   To unsubscribe from Quantum GIS - User,  click here . NAML View this message in context:  Re: poligonal entity copied from a layer to another appears in the table, not in the view Sent from the  Quantum GIS - User mailing list archive  at Nabble.com . _______________________________________________
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________ Qgis-user mailing list [hidden email] http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
[hidden email]
		http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178669.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178688.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141220/76035930/attachment.html>
