[Qgis-user] poligonal entity copied from a layer to another appears in the table, not in the view
Alessio Degioannini a.degioannini at proterstudio.com
Sat Dec 20 10:14:04 PST 2014
> check out to make sure its not a styling issue an
No, it is not a styling issue.
> send me the files if you can.
Ok. Tomorrow in the morning.
Thank you, Nicolas.
Alessio
Il 20/12/2014 17:32, Nicolas Cadieux ha scritto:
> Yes that could be it...  Sometime simple is better... But if he did a
> cut in paste in an empty file, then the file should not have styling
> properties....
> Alessio, check out to make sure its not a styling issue an send me the
> files if you can.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> Le 2014-12-20 08:21, "Joris Hintjens [via OSGeo.org]" <[hidden email]
> </user/SendEmail.jtp?type=node&node=5178688&i=0>> a écrit :
>     Hi Nicolas,
>      I have had same issues. In my case the problem was that the
>     target layer had styling properties. The new added elements had no
>     style and appeared blank. My advise; check the styling in the
>     layer properties.
>     Greets
>     Joris
>>     Op 20-dec.-2014, om 11:22 heeft Alessio Degioannini <[hidden
>>     email] </user/SendEmail.jtp?type=node&node=5178669&i=0>> het
>>     volgende geschreven:
>>     Hi Nicolas,
>>>     Try copying the content of the second file to an empty file to
>>>     see what happens.  If that works, try copying the content of the
>>>     first file in that new file and see what happens.
>>     Nothing.... Same issue: new record ok, no new entity in view.
>>>     Could it be a projection problem?  Look to see if both files are
>>>     in the same projection.  I usually use cut and paste between two
>>>     file with the same CRS.
>>     Every layer is in the same projection.
>>     Every layer is polygonal.
>>     Weird a lot!
>>     Thank you,
>>     Alessio
>>     Il 19/12/2014 15:06, Nicolas Cadieux ha scritto:
>>     Hi,
>>     Sounds weird.  Try copying the content of the second file to an
>>     empty file to see what happens.  If that works, try copying the
>>     content of the first file in that new file and see what happens.
>>     Le 2014-12-19 04:49, "Alessio Degioannini [via OSGeo.org
>>     <http://OSGeo.org>] " <<a moz-do-not-send="true"
>>     href="x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=0"
>>     target="_top" rel="nofollow" link="external" class="">[hidden
>>     email]> a écrit :
>>     Hi,
>>     I've just copied an entity from a poligonal layer to another.
>>     No geometry or topology error in the source layer, no geo/top
>>     errror in
>>     the target layer before pasting the new entity.
>>     After pasting: in the target layer table appears the espected new
>>     record, in the view: nothing. No reply to zoom to selected command.
>>     Check geometry freezes. Check topology ok.
>>     Help me, please.
>>     Thanks in advance.
>>     Alessio
>>     _______________________________________________
>>     Qgis-user mailing list
>>     href="x-msg://3/user/SendEmail.jtp?type=node&node=5178522&i=0"
>>     target="_top" rel="nofollow" link="external" class="">[hidden email]
>>     http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     If you reply to this email, your message will be added to the
>>     discussion below:
>>     http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522.html
>>     To start a new topic under Quantum GIS - User, email<a
>>     href="x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=1"
>>     To unsubscribe from Quantum GIS - User,click here.
>>     NAML
>>     <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>     View this message in context:Re: poligonal entity copied from a
>     <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178555.html>
>     Sent from theQuantum GIS - User mailing list archive
>     <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>at
>     Nabble.com <http://Nabble.com>.
>     [hidden email]  </user/SendEmail.jtp?type=node&node=5178669&i=1>
> [hidden email] </user/SendEmail.jtp?type=node&node=5178669&i=2>
> [hidden email] </user/SendEmail.jtp?type=node&node=5178669&i=3>
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178669.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> </user/SendEmail.jtp?type=node&node=5178688&i=1>
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> View this message in context: Re: poligonal entity copied from a layer
> <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178688.html>
> Sent from the Quantum GIS - User mailing list archive
> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141220/1cc64751/attachment.html>
