[Qgis-user] poligonal entity copied from a layer to another appears in the table, not in the view
Carlos López PSIG
carlos.lopez at psig.es
Sat Dec 20 10:39:38 PST 2014
Be careful with the "Snapping Options..." (Menu Settings) , perhaps you
have "Avoid intersection" in one layer.
Best regards,
* <http://www.psig.es>*
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
2014-12-20 19:14 GMT+01:00 Alessio Degioannini <
a.degioannini at proterstudio.com>:
> check out to make sure its not a styling issue an
> No, it is not a styling issue.
> send me the files if you can.
> Ok. Tomorrow in the morning.
> Thank you, Nicolas.
> Alessio
> Il 20/12/2014 17:32, Nicolas Cadieux ha scritto:
> Yes that could be it... Sometime simple is better... But if he did a cut
> in paste in an empty file, then the file should not have styling
> properties....
> Alessio, check out to make sure its not a styling issue an send me the
> files if you can.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112 Fax: 514.381.4995
> Le 2014-12-20 08:21, "Joris Hintjens [via OSGeo.org]" <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5178688&i=0>> a écrit :
> Hi Nicolas,
> I have had same issues. In my case the problem was that the target layer
> had styling properties. The new added elements had no style and appeared
> blank. My advise; check the styling in the layer properties.
> Greets
> Joris
> Op 20-dec.-2014, om 11:22 heeft Alessio Degioannini <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5178669&i=0>> het volgende
> geschreven:
> Hi Nicolas,
> Try copying the content of the second file to an empty file to see what
> happens. If that works, try copying the content of the first file in that
> new file and see what happens.
> Nothing.... Same issue: new record ok, no new entity in view.
> Could it be a projection problem? Look to see if both files are in the
> same projection. I usually use cut and paste between two file with the
> same CRS.
> Every layer is in the same projection.
> Every layer is polygonal.
> Weird a lot!
> Thank you,
> Alessio
> Il 19/12/2014 15:06, Nicolas Cadieux ha scritto:
> Hi,
> Sounds weird. Try copying the content of the second file to an empty file
> to see what happens. If that works, try copying the content of the first
> file in that new file and see what happens.
> same CRS.
> Le 2014-12-19 04:49, "Alessio Degioannini [via OSGeo.org] " <<a
> moz-do-not-send="true"
> href="x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=0"
> target="_top" rel="nofollow" link="external" class="">[hidden email]> a
> écrit :
> Hi,
> I've just copied an entity from a poligonal layer to another.
> No geometry or topology error in the source layer, no geo/top errror in
> the target layer before pasting the new entity.
> After pasting: in the target layer table appears the espected new
> record, in the view: nothing. No reply to zoom to selected command.
> Check geometry freezes. Check topology ok.
> Help me, please.
> Thanks in advance.
> Alessio
> Qgis-user mailing list
> <a moz-do-not-send="true"
> href="x-msg://3/user/SendEmail.jtp?type=node&node=5178522&i=0"
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522.html
> To start a new topic under Quantum GIS - User, email <a
> href="x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=1"
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: poligonal entity copied from a layer to
> <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178555.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
> Qgis-user mailing list[hidden email] <http:///user/SendEmail.jtp?type=node&node=5178669&i=1>http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5178669&i=2>
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5178669&i=3>
> below:
> http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178669.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5178688&i=1>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178688.html>
> Nabble.com.
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141220/db87170c/attachment.html>
