[Qgis-user] poligonal entity copied from a layer to another appears in the table, not in the view
Alessio Degioannini a.degioannini at proterstudio.com
Sun Dec 21 03:29:50 PST 2014
Thank you, Carlos
but the new polygon has no common borders with other polygons and option
"avoid intersection" is not on.
Alessio
Alessio Degioannini - dottore forestale
PROTER - Studio Associato Agronomico e Forestale
C.so Stati Uniti, 27 - 10128 TORINO (ITALY)
Tel: +39 011 817 0767
Fax: +39 011 070 2382
Cell.: +39 329 211 2781
E-mail: a.degioannini at proterstudio.com
P.E.C.: a.degioannini at epap.conafpec.it
Il 20/12/2014 19:39, Carlos López PSIG ha scritto:
> Hi,
> Be careful with the "Snapping Options..." (Menu Settings) , perhaps
> you have "Avoid intersection" in one layer.
> Best regards,
> *<http://www.psig.es>
> *Carlos López Quintanilla*
> www.psig.es <http://www.psig.es>
> carlos.lopez at psig.es <mailto:carlos.lopez at psig.es>
> +34 699.680.261
> 2014-12-20 19:14 GMT+01:00 Alessio Degioannini
> <a.degioannini at proterstudio.com <mailto:a.degioannini at proterstudio.com>>:
>>     check out to make sure its not a styling issue an
>     No, it is not a styling issue.
>>     send me the files if you can.
>     Ok. Tomorrow in the morning.
>     Thank you, Nicolas.
>     Alessio
>     Il 20/12/2014 17:32, Nicolas Cadieux ha scritto:
>>     Yes that could be it...  Sometime simple is better... But if he
>>     did a cut in paste in an empty file, then the file should not
>>     have styling properties....
>>     Alessio, check out to make sure its not a styling issue an send
>>     Nicolas Cadieux M.Sc.
>>     Les Entreprises Archéotec inc.
>>     8548, rue Saint-Denis Montréal H2P 2H2
>>     Téléphone: 514.381.5112  Fax: 514.381.4995
>>     Le 2014-12-20 08:21, "Joris Hintjens [via OSGeo.org]" <[hidden
>>     email] <http:///user/SendEmail.jtp?type=node&node=5178688&i=0>> a
>>     écrit :
>>         Hi Nicolas,
>>          I have had same issues. In my case the problem was that the
>>         target layer had styling properties. The new added elements
>>         had no style and appeared blank. My advise; check the styling
>>         in the layer properties.
>>         Greets
>>         Joris
>>>         Op 20-dec.-2014, om 11:22 heeft Alessio Degioannini <[hidden
>>>         email]
>>>         <http:///user/SendEmail.jtp?type=node&node=5178669&i=0>> het
>>>         volgende geschreven:
>>>         Hi Nicolas,
>>>>         Try copying the content of the second file to an empty file
>>>>         to see what happens.  If that works, try copying the
>>>>         content of the first file in that new file and see what
>>>>         happens.
>>>         Nothing.... Same issue: new record ok, no new entity in view.
>>>>         Could it be a projection problem?  Look to see if both
>>>>         files are in the same projection.  I usually use cut and
>>>>         paste between two file with the same CRS.
>>>         Every layer is in the same projection.
>>>         Every layer is polygonal.
>>>         Weird a lot!
>>>         Thank you,
>>>         Alessio
>>>         Il 19/12/2014 15:06, Nicolas Cadieux ha scritto:
>>>         Hi,
>>>         Sounds weird.  Try copying the content of the second file to
>>>         an empty file to see what happens.  If that works, try
>>>         copying the content of the first file in that new file and
>>>         see what happens.
>>>         Could it be a projection problem?  Look to see if both files
>>>         are in the same projection.  I usually use cut and paste
>>>         Le 2014-12-19 04:49, "Alessio Degioannini [via OSGeo.org
>>>         <http://OSGeo.org>] " <<a moz-do-not-send="true"
>>>         href="x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=0"
>>>         target="_top" rel="nofollow" link="external"
>>>         class="">[hidden email]> a écrit :
>>>         Hi,
>>>         I've just copied an entity from a poligonal layer to another.
>>>         No geometry or topology error in the source layer, no
>>>         geo/top errror in
>>>         the target layer before pasting the new entity.
>>>         After pasting: in the target layer table appears the
>>>         espected new
>>>         record, in the view: nothing. No reply to zoom to selected
>>>         command.
>>>         Check geometry freezes. Check topology ok.
>>>         Help me, please.
>>>         Thanks in advance.
>>>         Alessio
>>>         _______________________________________________
>>>         Qgis-user mailing list
>>>         href="x-msg://3/user/SendEmail.jtp?type=node&node=5178522&i=0"
>>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>         If you reply to this email, your message will be added to
>>>         the discussion below:
>>>         http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522.html
>>>         To start a new topic under Quantum GIS - User, email<a
>>>         href="x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=1"
>>>         To unsubscribe from Quantum GIS - User,click here.
>>>         NAML
>>>         <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>         View this message in context:Re: poligonal entity copied from
>>         <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178555.html>
>>         Sent from theQuantum GIS - User mailing list archive
>>         <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>at
>>         Nabble.com <http://Nabble.com>.
>>         [hidden email]  <http:///user/SendEmail.jtp?type=node&node=5178669&i=1>
>>     [hidden email]
>>     <http:///user/SendEmail.jtp?type=node&node=5178669&i=2>
>>     [hidden email]
>>     <http:///user/SendEmail.jtp?type=node&node=5178669&i=3>
>>     If you reply to this email, your message will be added to the
>>     discussion below:
>>     http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178669.html
>>     To start a new topic under Quantum GIS - User, email [hidden
>>     email] <http:///user/SendEmail.jtp?type=node&node=5178688&i=1>
>>     To unsubscribe from Quantum GIS - User, click here.
>>     NAML
>>     View this message in context: Re: poligonal entity copied from a
>>     <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178688.html>
>>     Sent from the Quantum GIS - User mailing list archive
>>     at Nabble.com.
>>     Qgis-user at lists.osgeo.org  <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141221/ce9d373b/attachment.html>
