[Qgis-user] poligonal entity copied from a layer to another appears in the table, not in the view
Alessio Degioannini a.degioannini at proterstudio.com
Mon Dec 22 02:24:58 PST 2014
> It appears to be a problem with your Qgis installation.
You are right: it really is a problem with the installation of Qgis
under Windows 8.1.
Now I am working with Qgis Brighton under Ubuntu and everything works
perfectly!
I want to specify that, when I installed Windows Qgis Brighton, before I
removed the previous version (Chugiak) and I deleted all folders and
registry keys related to Qgis and, only later, I installed Brighton.
As soon as possible I'll just make the reinstallation in the same way
and will inform you of the result.
Thanks again and best wishes.
Alessio
Il 21/12/2014 16:45, nicolas.cadieux at archeotec.ca ha scritto:
> Hi,
> It appears to be a problem with your Qgis installation.  I was able to
> open both file and modify them both ways.  I assumed the CRS was wgs84
> (it is not).  I would do a complete reinstall and make sure you remove
> the registry keys in the windows registry. You can also backup then
> erase the .qgis2 folder (your plugins).
> I have sent you back both files plus a project plus file I did the
> "Save as" (they are in the wrong projection).  You can see that you
> are missing some files for yours layers but it does not appear to be a
> problem for now.  Did you try to modify the files on a server or from
> your hard drive?
> Nicolas
> Le 2014-12-21 07:16, Alessio Degioannini a écrit :
>>> send me the files if you can
>> attached shapefiles:
>>   * target layer: where to past the new polygon
>>   * layer containing the polygon to be added to target layer.
>> Try to do, and wonder...
>> Thank you and best regards.
>> Alessio
>> Il 20/12/2014 17:32, Nicolas Cadieux ha scritto:
>>> Yes that could be it...  Sometime simple is better... But if he did
>>> a cut in paste in an empty file, then the file should not have
>>> styling properties....
>>> Alessio, check out to make sure its not a styling issue an send me
>>> the files if you can.
>>> Nicolas Cadieux M.Sc.
>>> Les Entreprises Archéotec inc.
>>> 8548, rue Saint-Denis Montréal H2P 2H2
>>> Téléphone: 514.381.5112  Fax: 514.381.4995
>>> Le 2014-12-20 08:21, "Joris Hintjens [via OSGeo.org]" <[hidden
>>> email] </user/SendEmail.jtp?type=node&node=5178688&i=0>> a écrit :
>>>     Hi Nicolas,
>>>      I have had same issues. In my case the problem was that the
>>>     target layer had styling properties. The new added elements had
>>>     no style and appeared blank. My advise; check the styling in the
>>>     layer properties.
>>>     Greets
>>>     Joris
>>>>     Op 20-dec.-2014, om 11:22 heeft Alessio Degioannini <[hidden
>>>>     email] </user/SendEmail.jtp?type=node&node=5178669&i=0>> het
>>>>     volgende geschreven:
>>>>     Hi Nicolas,
>>>>>     Try copying the content of the second file to an empty file to
>>>>>     see what happens.  If that works, try copying the content of
>>>>>     the first file in that new file and see what happens.
>>>>     Nothing.... Same issue: new record ok, no new entity in view.
>>>>>     Could it be a projection problem?  Look to see if both files
>>>>>     are in the same projection.  I usually use cut and paste
>>>>>     between two file with the same CRS.
>>>>     Every layer is in the same projection.
>>>>     Every layer is polygonal.
>>>>     Weird a lot!
>>>>     Thank you,
>>>>     Alessio
>>>>     Il 19/12/2014 15:06, Nicolas Cadieux ha scritto:
>>>>     Hi,
>>>>     Sounds weird.  Try copying the content of the second file to an
>>>>     empty file to see what happens.  If that works, try copying the
>>>>     content of the first file in that new file and see what happens.
>>>>     Le 2014-12-19 04:49, "Alessio Degioannini [via OSGeo.org
>>>>     <http://OSGeo.org>] " <<a moz-do-not-send="true"
>>>>     href="x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=0"
>>>>     target="_top" rel="nofollow" link="external" class="">[hidden
>>>>     email]> a écrit :
>>>>     Hi,
>>>>     I've just copied an entity from a poligonal layer to another.
>>>>     No geometry or topology error in the source layer, no geo/top
>>>>     errror in
>>>>     the target layer before pasting the new entity.
>>>>     After pasting: in the target layer table appears the espected new
>>>>     record, in the view: nothing. No reply to zoom to selected command.
>>>>     Check geometry freezes. Check topology ok.
>>>>     Help me, please.
>>>>     Thanks in advance.
>>>>     Alessio
>>>>     _______________________________________________
>>>>     Qgis-user mailing list
>>>>     href="x-msg://3/user/SendEmail.jtp?type=node&node=5178522&i=0"
>>>>     email]
>>>>     http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>     If you reply to this email, your message will be added to the
>>>>     discussion below:
>>>>     http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522.html
>>>>     To start a new topic under Quantum GIS - User, email<a
>>>>     href="x-msg://3/user/SendEmail.jtp?type=node&node=5178555&i=1"
>>>>     email]
>>>>     To unsubscribe from Quantum GIS - User,click here.
>>>>     NAML
>>>>     <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>>>     View this message in context:Re: poligonal entity copied from a
>>>     <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178555.html>
>>>     Sent from theQuantum GIS - User mailing list archive
>>>     <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>at
>>>     Nabble.com <http://Nabble.com>.
>>>     [hidden email]  </user/SendEmail.jtp?type=node&node=5178669&i=1>
>>> [hidden email] </user/SendEmail.jtp?type=node&node=5178669&i=2>
>>> [hidden email] </user/SendEmail.jtp?type=node&node=5178669&i=3>
>>> discussion below:
>>> http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178669.html
>>> To start a new topic under Quantum GIS - User, email [hidden email]
>>> </user/SendEmail.jtp?type=node&node=5178688&i=1>
>>> To unsubscribe from Quantum GIS - User, click here.
>>> NAML
>>> View this message in context: Re: poligonal entity copied from a
>>> <http://osgeo-org.1560.x6.nabble.com/poligonal-entity-copied-from-a-layer-to-another-appears-in-the-table-not-in-the-view-tp5178522p5178688.html>
>>> Sent from the Quantum GIS - User mailing list archive
>>> at Nabble.com.
>>> Qgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141222/78a89d2c/attachment.html>
