[Qgis-user] Storing data to postgis from Qgis
David Kramer davidk at gmail.com
Tue Dec 30 08:59:21 PST 2014
On Tue, Dec 30, 2014 at 5:24 AM, Jan Michálek <godzilalalala at gmail.com>
wrote:
> In db manager you can import data in new table or add features to an
> existing table.
> Or you can add empty column to a table, select in qgis desktop, open
> atribute table, display selected features on top and edit empty column by
> your atributes.
Hi Jan,
Sorry I'm not following your explanation of editing attribute table. I know
you can db edit tables in QGIS, but I don't see how to get data from a
layer to a row of a db via the db manager interface. I see only four action
icons (screenshot below) namely "refresh", "SQL window", "import
layer/file" and "export to file".
[image: Inline image 1]
I've been playing around with the import function. I can successfully
import a layer into a new table in the db but if I try to import to an
existing table it errors out and tells me that the table already exists. I
obviously don't want to drop the existing table.
Thanks
David
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141230/0cdedfe8/attachment.html>
Name: Screen Shot 2014-12-30 at 8.47.02 AM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141230/0cdedfe8/attachment.png>
