[Qgis-user] Storing data to postgis from Qgis
Junior Delaz delazj at gmail.com
Tue Dec 30 11:08:54 PST 2014
It's not (yet) possible to append data to an existing table through
DBManager.
i may not understand well your question but What about adding both source
and destination tables and just select features, copy and paste them from
the source table to the detination one?
2014-12-30 17:59 GMT+01:00 David Kramer <davidk at gmail.com>:
> On Tue, Dec 30, 2014 at 5:24 AM, Jan Michálek <godzilalalala at gmail.com>
> wrote:
>> In db manager you can import data in new table or add features to an
>> existing table.
>> Or you can add empty column to a table, select in qgis desktop, open
>> atribute table, display selected features on top and edit empty column by
>> your atributes.
> Hi Jan,
> Sorry I'm not following your explanation of editing attribute table. I
> know you can db edit tables in QGIS, but I don't see how to get data from a
> layer to a row of a db via the db manager interface. I see only four action
> icons (screenshot below) namely "refresh", "SQL window", "import
> layer/file" and "export to file".
> [image: Inline image 1]
> I've been playing around with the import function. I can successfully
> import a layer into a new table in the db but if I try to import to an
> existing table it errors out and tells me that the table already exists. I
> obviously don't want to drop the existing table.
> Thanks
> David
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141230/23b68ece/attachment.html>
Name: Screen Shot 2014-12-30 at 8.47.02 AM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141230/23b68ece/attachment.png>
