[Qgis-user] QGIS 2.0 label problem
Lester Anderson arctica1963 at gmail.com
Sat Feb 1 01:16:34 PST 2014
There should be a proper solution. In my work, I often have clipped raster
layers which are contoured and labelled, and I wish to compare these with a
larger dataset (also contoured and labelled). If the vector contour layer
is covered by the opaque overlying raster, then so to should the labels for
that vector layer - this is just common logic.
I think this labelling issue needs to be addressed by the developers as it
is clearly a flaw. Take it to the extreme and have the top raster totally
covering the lower one that has a vector contour layer labelled, and you
immediately see the incosistency.
There is no workaround for this problem from what I can see.
Cheers
Lester
On 1 February 2014 08:13, Harish <harry.om2000 at gmail.com> wrote:
> There should be solution when user user does not want labels of underlying
> layers to be shown, without making the labels invisible.
> Regards
> On Sat, Feb 1, 2014 at 12:27 AM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>> Hey Lester,
>> Labels always render above all other layers.
>> - Nathan
>> On Sat, Feb 1, 2014 at 9:55 AM, Lester Anderson <arctica1963 at gmail.com>wrote:
>>> Hello
>>> I have a issue with labels. If I have a base raster, overlay a contour
>>> layer with labels, and then a top raster, the labels from the underlying
>>> contour vector layer show when they should be covered - why should that be ?
>>> Cheers
>>> Lester
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Harish Kumar Solanki, Assistant Professor
> National Institute of Rural Development (NIRD), Jaipur Center
> Ministry of Rural Development, Government of India
> Chaupal, Near Railway Station
> Jaipur -302006
> Geo_Coordinates (Office): 26.92162 N, 75.78921 E
> Email- hksolanki at nird.gov.in, harry.om2000 at gmail.com,
> Phone (Office) - 0141-2209904, Fax- 0141-2209905
> Mo.- 09214446732, 09414291732
> Website-  http://www.nird.org.in, <http://www.nird.org.in>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140201/1ffb86dd/attachment.html>
