[Qgis-user] Help with Orfeotoolbox in QGIS 2.0.1
José Pedro Santos zpsantos1 at hotmail.com
Sun Feb 2 04:08:31 PST 2014
Hi Travis,
Orfeo Toolbox already came as a package inside the "Processing plugin"
but to enable it you have to go to the processing Options and choose the
 option "activate". Check if the paths exist or they are correct. I have
 on Ubuntu 12.04 LTS the following ones:
OTB applications folder: /usr/lib/otb/
OTB command line tools folder: /usr/lib/
The location of OTB on QGIS 2.0 is different from QGIS 1.8
Good luck.
Best Regards,
José Santos
Date: Thu, 30 Jan 2014 11:03:18 -0800
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Help with Orfeotoolbox in QGIS 2.0.1
I want to use the Binary Morphological Operation tool listed in the Processing Toolbox in QGIS, but after many hours of searching I still can't get it to work (the tool gives an error message that either says the folders are not configured, or that the output can't be created).  I believe the problem is that I don't know what folder paths to use for the "OTB Applications" and "OTB command line tools" folders in the processing options window.  I have read any documentation I could find with a Google search or searching the QGIS documentation but I still haven't had any luck.  Any suggestions?
Travis
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140202/339e5e4d/attachment.html>
