[Qgis-user] How do I register a Google Map?
Randal Hale rjhale at northrivergeographic.com
Wed Feb 5 09:25:05 PST 2014
So I work with Forestry guys and we do some very similar things when
georeferencing. You need a good point spacing - and typically I describe
that as a point at each coner of the image you are going to georeference
plus one for the middle or (sorry for using this example but they have
really good docs) -
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Georeferencing_a_raster_dataset
If it were me I would do this:
1. go to USDA Datagateway - http://datagateway.nrcs.usda.gov/ - and
download a NAIP image of your Area (sorted by county). It will be sid
format (probably) - so if you are on windows you should be OK for
opening up the image.
2. Use that to georeference the Google earth Screenshot. It will give
you a lot more control points than just your GPS.
  * GPS can be notorious for not quite being right if you didn't way
    point average - my forestry guys GPS property corners and that makes
    me not happy every time they do it.
  * Both Google and Bing are good and the open layers plugin rocks - but
    - both image layers aren't captured (at least to me) with mapping in
    mind - i.e. they may be questionable.
OR
1. Download the GPX data from your unit using either QGIS or DNR GPS
2. Convert to shapefile.
3. Create your contours there using a new shapefile (digitize them in
again).
I know I just glassed over a ton of technical by doing a 1 2 3 type
scenario but I think (just my opinion) there's more hair pulling than
you need to be experiencing (For the record I'm bald so I know all about
hair pulling).
Yell if you need more help either off list or on list - I hope some of
this at least pushes you in a good direction.
Randy
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
<mailto:rjhale at northrivergeographic.com>
twitter:rjhale
http://about.me/rjhale
On 02/05/2014 12:04 PM, Mike Keelan wrote:
> Thanks James,
> I got through the geo-referencing operation and  it did generate a new
> modified layer based on my .jpg.  However the new layer is badly
> distorted/stretched, (I used 4 coordinate Garmin GPS reference
> points), and it is not in the right location.  I can only find it by
> zooming to that layer extent.  I'm wondering if my coordinate data
> from my Garmin is consistent with what the geo-referencing program
> uses?  My Garmin data is xx.xxxxxx and it uses negative numbers to
> represent East instead of West.  Or, might there be an accuracy issue?
> I know my Garmin way-point data is good because it overlays on my
> Ortho almost perfectly as a separate layer.
> Mike K
> On 2/3/2014 8:28 PM, James Wood wrote:
>> Mike,
>> Here is a good tutorial overview of the georeferencing tool in QGIS:
>> http://qgis.spatialthoughts.com/2012/02/tutorial-georeferencing-topo-sheets.html
>> If the image is not in coordinate space, it will not line up with
>> your other data. so this operation will be necessary.
>> Also, just as a side, I would think that an export from Powerpoint
>> would degrade image quality (depending on the original). I would look
>> at and maybe try for future use The Gimp (which is an open source,
>> free Photoshop-type application). It will give you more control on
>> export of not only various output formats but also pixel and color
>> depth, and the like. The official site is http://www.gimp.org/.
>> Best Regards,
>> James
>> Date: Mon, 3 Feb 2014 19:59:14 -0500
>> From: tmike.elhoa at comcast.net
>> To: tech at wildintellect.com; etourigny.dev at gmail.com
>> CC: qgis-user at lists.osgeo.org
>> Subject: Re: [Qgis-user] How do I register a Google Map?
>> OK, I installed the Open Layers plugin and it works very nice but it
>> won't do what I need, so let me be more specific and see if there
>> might be a remedy.
>> The contour lines that I want were actually obtained using a hand
>> held Garman GPS.  The Garman data was overlaid on the Google map,
>> (with water depths),  special integration,  then that map was
>> exported as a Jpeg, then imported to PowerPoint where a visual
>> interpolation was done to make the final set of contour lines for the
>> various lake water depths.
>> My desire is the _digitize_ these contour lines as a set of separate
>> layers. ie 5' deep, 10' deep, etc.  There are many good uses for
>> these layers,  but they must be accurate as to location and size.  I
>> don't think I necessarily need spacial info on the "map"/Jpeg if I
>> can get the whole map in the right position, and size, so I can do
>> the digitizing (which would then have the spacial info).  Then I can
>> discard the Jpeg.
>> Is it hopeless?
>> Mike K
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140205/20d3131c/attachment.html>
