[Qgis-user] Add data file xls
Siki Zoltan siki at agt.bme.hu
Thu Feb 6 01:14:37 PST 2014
Dear Marillena,
you can open speadsheet data (xls, xlsx) with open vector data, you must
select all files in the dialog to see speadsheet files.
You can join the speadsheet to the shapefile joinning them. In the
shapefile properties dialog look for join tab.
Best regards,
Zoltan
On Thu, 6 Feb 2014, labiancamarilena at libero.it wrote:
> Hi all,
> I should create a thematic map, I've created the shapefile, but I should add
> an spreadsheet (Excel) that contains a lot of data; these data should be
> associated to the attributes of the shapefile (for example, for each
> municipality identified with a ZIP code associate its  socio-economic data)
> How can I do?
> thanks
> Marilena
> Qgis-user mailing list
