[Qgis-user] Add data file xls
José Pedro Santos zpsantos1 at hotmail.com
Thu Feb 6 01:28:57 PST 2014
Hey,
Follow this tutorial:
http://www.qgistutorials.com/en/docs/importing_spreadsheets_csv.html
Regards,
José Santos
> Date: Thu, 6 Feb 2014 10:14:37 +0100
> From: siki at agt.bme.hu
> To: labiancamarilena at libero.it
> CC: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Add data file xls
> Dear Marillena,
> you can open speadsheet data (xls, xlsx) with open vector data, you must
> select all files in the dialog to see speadsheet files.
> You can join the speadsheet to the shapefile joinning them. In the
> shapefile properties dialog look for join tab.
> Best regards,
> Zoltan
> On Thu, 6 Feb 2014, labiancamarilena at libero.it wrote:
> > Hi all,
> > I should create a thematic map, I've created the shapefile, but I should add
> > an spreadsheet (Excel) that contains a lot of data; these data should be
> > associated to the attributes of the shapefile (for example, for each
> > municipality identified with a ZIP code associate its  socio-economic data)
> > How can I do?
> > thanks
> > Marilena
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140206/f136c391/attachment.html>
