[Qgis-user] Transformation using NTv2 grids
Robert Nuske rnuske at gwdg.de
Thu Feb 6 01:38:57 PST 2014
Hi Marco
thanks for your insightful answer.
> >Is this already in 2.1?
> >If yes, where could one find it?
> There is a dialog showing the available datum transformations. This
> dialog shows up as soon as a layer needs a datum transformation (e.g. if
> on-the-fly reprojection is toggled or when doing save as'). However, the
> ntv2 transformation info has to be inserted into srs.db / table
> datum_transform first.
I've seen that dialog in 2.1 but couldn't find an entry for ntv2?
Will the datum_transform table have entries for common ntv2-transformations
when 2.2 is released?
cheers
  robert
