[Qgis-user] Interprocess communication
José Pedro Santos
zpsantos1 at hotmail.com
Fri Feb 7 04:34:49 PST 2014
Hey,
Try to use the Phyton console http://pythonwebconsole.thomnichols.org/
There's also another alternatives but I never used them.
Good luck
Best Regards,
José Santos
To: zpsantos1 at hotmail.com
Subject: AW: [Qgis-user] Interprocess communication
Date: Fri, 7 Feb 2014 11:53:35 +0100
Hi Jose, thank you for your answer. Yes, I mean a connection to qgis from other programs. For example, in ArcGIS I can get the main application using COM, with that I can get access to all other parts of ArcGIS: layers, GUI components etc. In QGIS I haven’t seen such a possibility, most probably because I know QGIS very little. I’ve read in forum one can use a timer in plugin. It should be possible, I think. But perhaps is there a more elegant way? Best regards,Gang Von: José Pedro Santos [mailto:zpsantos1 at hotmail.com]
Gesendet: Freitag, 7. Februar 2014 11:37
An: Gang Yang; QGIS Mailing List
Betreff: RE: [Qgis-user] Interprocess communication Hi Gang,
Can you be more specific with your question please.
Basically you want to connect other program with QGIS?!
Kind Regards,
José Santos From: gang.yang at freenet.de
To: qgis-user at lists.osgeo.org
Date: Thu, 6 Feb 2014 18:40:23 +0100
Subject: [Qgis-user] Interprocess communicationHi, I’m new to QGIS and now using QGIS 2.0.1 on Windows PC (Windows 8). I have a question about QGIS communication with other application on the same machine, concretely, I would like to send some data to qgis from another program and let qgis, for example, zoom to the corresponding object. I’ve searched in the documentation and in internet. But I’ve found no proper answer. I hope someone can point me to a right direction. Thank you in advance and best regards Gang
_______________________________________________ Qgis-user mailing list Qgis-user at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140207/43ac2106/attachment.html>
