[Qgis-user] version - 1.8.0 -> 2.0.1
Richard McDonnell richard.mcdonnell at opw.ie
Mon Feb 10 06:16:42 PST 2014
Do you require OSMEditor?
If you don't, go to Plugins, manage and install Plugins. A list of
Plugins will be shown under "Installed" the plugin causing the error
will be in red (red writing) click on it and select "Uninstall plugin"
restart QGIS and you should be fine after that.
If you do require OSMEditor, there is a Plugin called
OSMEditorRemoteControl, I am unsure as to if it is exactly the same as
the old plugin, but installing this may also help.
Regards,
Richard.
On 10/02/2014 13:45, Luca Manganelli wrote:
> On Mon, Feb 10, 2014 at 8:57 AM, Gabriele Baccini <gbaccini at yahoo.it
> <mailto:gbaccini at yahoo.it>> wrote:
>     Hello to all,
>     When I open a project I get the following error.
>     What should I do to resolve this error
>     thanks in advance
> It seems that it's a problem of your installed plugin (OSMEditor?).
> Try to disable it from Plugins List and then reload your old 1.8 project.
> Qgis-user mailing list
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140210/40abff4f/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140210/40abff4f/attachment.vcf>
