[Qgis-user] version - 1.8.0 -> 2.0.1
Andre Joost andre+joost at nurfuerspam.de
Mon Feb 10 07:47:34 PST 2014
Am 10.02.2014 08:57, schrieb Gabriele Baccini:
> Hello to all,
> When I open a project I get the following error.
> What should I do to resolve this error
> thanks in advance
> Gabriele
> Windows 7 64
> i5 2410m
> Errore durante l'esecuzione di codice Python:
> Traceback (most recent call last):
>    File "C:\Users\fufi/.qgis2/python/plugins\OSMEditorRemoteControl\plugin.py", line 32, in changeStatus
>      extent = self.getLonLatExtent()
>    File "C:\Users\fufi/.qgis2/python/plugins\OSMEditorRemoteControl\plugin.py", line 27, in getLonLatExtent
>      return QgsCoordinateTransform(crs_map, crs_4326).transform(extent)
> QgsCsException: trasformazione diretta di
> (nan, nan)
> PROJ.4: +proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0 +ellps=intl +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68 +units=m +no_defs +to +proj=longlat +datum=WGS84 +no_defs
> Errore: non-convergent inverse meridional dist
What extent does your map have? tmerc can only handle longitudes between
lon_0 +/-90°.
You can try again by creating a project in EPSG:4326, and load the
layers to that. Or remove the OSMEditorRemoteControl plugin before
openig the project.
HTH,
André Joost
