[Qgis-user] layers have sometimes have to be turned on and, off and on again to show up
Jake Maier j.m at jmforestry.com
Tue Feb 11 07:41:50 PST 2014
Thank you Reiko
I checked and the drawing order is checked. I normally don't change that, but who knows. I'll keep an eye on it. Unfortunately, I can't reproduce it, so I have to wait till it happens again.
Thanks
Jake
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Hayashi Reiko
Sent: Tuesday, February 11, 2014 9:37 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] layers have sometimes have to be turned on and, off and on again to show up
I had the same problem, but found out that there is a checkbox "Update drawing order" at the bottom of the context menu which shows up by right-clicking the layer in layers tab.
My problem was solved by checking this box. I wonder if I am responding to your question...
林玲子 Reiko Hayashi
2014-02-11 22:31 GMT+09:00 Mike Flannigan <mikeflan at att.net>:
> I suspect you are familiar with layer drawing order.
> If not, drag different layers that display in the "Layers" box on the
> left side to the top of the list.
> If that is not the problem what is your OS and QGIS version number?
> Mike
> On 2/10/2014 9:29 AM, qgis-user-request at lists.osgeo.org wrote:
>> Date: Sun, 9 Feb 2014 20:00:13 -0500
>> From: "Jake Maier"<j.m at jmforestry.com>
>> To:<qgis-user at lists.osgeo.org>
>> Subject: [Qgis-user] layers have sometimes have to be turned on and
>> Message-ID:<01a001cf25fb$753b8e10$5fb2aa30$@m at jmforestry.com>
>> Content-Type: text/plain; charset="us-ascii"
>> Since qgis 1.8, I sometimes have to turn layers on and off and on again,
>> sometime 3 or 4 times, to make them show on the canvas. This is not a
>> consistent problem
>> Does anyone know what the problem may be?
>> Jake
> Qgis-user mailing list
