[Qgis-user] layers have sometimes have to be turned on and, off and on again to show up
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed Feb 12 14:46:33 PST 2014
Jake,
That's right. OpenLayre is a plugin layer. In my case, it is Crayfish
layer which seems to cause the problem to happen more often.
Cheers,
Saber
-----Original Message-----
To: 'Saber Razmjooei' <saber.razmjooei at lutraconsulting.co.uk>, 'Hayashi
Reiko' <hayashi at linz.jp>, qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] layers have sometimes have to be turned on and,
Date: Wed, 12 Feb 2014 07:10:48 -0500
Saber, thanks for your answer. What do you mean with a plugin layer
I had a openlayer google layer loaded but only on this last incident
Before it also happened without an openlayer layer loaded
Jake
From: Saber Razmjooei [mailto:saber.razmjooei at lutraconsulting.co.uk]
Sent: Wednesday, February 12, 2014 4:14 AM
To: 'Jake Maier'; 'Hayashi Reiko'; qgis-user at lists.osgeo.org
Subject: RE: [Qgis-user] layers have sometimes have to be turned on and, off and on again to show up
Do you happen to have a "plugin layer" loaded?
For me it happens more often if I have a plugin layer loaded.
Cheers,
Saber
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jake Maier
Sent: 11 February 2014 15:42
To: 'Hayashi Reiko'; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] layers have sometimes have to be turned on and, off and on again to show up
Thank you Reiko
I checked and the drawing order is checked. I normally don't change that, but who knows. I'll keep an eye on it. Unfortunately, I can't reproduce it, so I have to wait till it happens again.
Thanks
Jake
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Hayashi Reiko
Sent: Tuesday, February 11, 2014 9:37 AM
To: qgis-user at lists.osgeo.org
I had the same problem, but found out that there is a checkbox "Update drawing order" at the bottom of the context menu which shows up by right-clicking the layer in layers tab.
My problem was solved by checking this box. I wonder if I am responding to your question...
林玲子 Reiko Hayashi
2014-02-11 22:31 GMT+09:00 Mike Flannigan <mikeflan at att.net>:
> I suspect you are familiar with layer drawing order.
> If not, drag different layers that display in the "Layers" box on the
> left side to the top of the list.
> If that is not the problem what is your OS and QGIS version number?
> Mike
> On 2/10/2014 9:29 AM, qgis-user-request at lists.osgeo.org wrote:
>> Date: Sun, 9 Feb 2014 20:00:13 -0500
>> From: "Jake Maier"<j.m at jmforestry.com> To:<qgis-user at lists.osgeo.org>
>> Subject: [Qgis-user] layers have sometimes have to be turned on and
>> Message-ID:<01a001cf25fb$753b8e10$5fb2aa30$@m at jmforestry.com>
>> Content-Type: text/plain; charset="us-ascii"
>> Since qgis 1.8, I sometimes have to turn layers on and off and on
>> again, sometime 3 or 4 times, to make them show on the canvas. This
>> is not a consistent problem
>> Does anyone know what the problem may be?
>> Jake
> Qgis-user mailing list
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
