[Qgis-user] Qgis-server recompute always the layer bbox ?
Bernhard Ströbl bernhard.stroebl at jena.de
Fri Feb 14 01:58:23 PST 2014
Hi Marco,
I have a question in this context (I thought I made ticket but cannot
find it)
What is the sense of setting the bounding box in OWS tab if it is always
calculated to the sum of the bboxes of the layers in the project? IMHO
setting the bbox in the project properties should override any
calculation result.
Background: One of my layers became empty because a user deleted the
last record thus its bbox was calculated to be the whole earth resulting
in QGIS server propagating the whole earth as bbox for this project.
Bernhard
Am 14.02.2014 10:34, schrieb Marco Hugentobler:
> Hi Andrea, Giovanni
> QGIS Server doesn't calculate the bbox itself, but it queries the extent
> from the layers. So it can be that certain providers calculate the bbox
> (of course only if the layer / capabilities document is not cached).
> For a faster startup, having a persistent cache as Giovanni suggested
> might help.
> Regards,
> Marco
> On 14.02.2014 10:18, G. Allegri wrote:
>>     I don't understand why the qgis-server eed to calculate always the
>>     bbox.
>>     In the server project windows,
>>     qgis ask for the published bbox.
>>     Why it don't use it as bbox rather than calculate it on every
>>     request ?
>> Marco, correct me if I'm wrong.
>> QGIS Server doesn't calculate the BBOX, it parses the layers extents
>> from the .qgs project and then combine them to obtain the entire BBOX.
>> The only operation it does is reprojecting the extents to WGS84 to
>> create the EX_GeographicBoundingBox element.
>> Anyway, in case the project advertises and extent, the combined extent
>> won't be calculated, so in your case this phase shouldn't be the
>> bottleneck...
>> giovanni
>>     The FastCGI don't help really.
>>     In a publishing environment every few hour the instances are
>>     restated to removed zombi process.
>>     This mean that every few hours the FastCGI are emptied and reloaded.
>>     A fastcgi environment mean to load 20 instances of QGIS-server and
>>     every of them do them own elaboration .
>>     As the bbox calculation for every layer.
>>     GASP.
>>     The start could ask about one hours and more.
>>     Also another problem with the fastcig is that when
>>     I change something on a project I need to restart to Web instances
>>     to dismiss the actual project and reload the new.
>>     So every change in a qgis project need a restart of all proccess
>>     (20 and so on in a fastcgi enviroment) every with a slow bbox
>>     calculation phase.
>>     mmhh...
>>     2014-02-14 9:13 GMT+01:00 G. Allegri <giohappy at gmail.com
>>     <mailto:giohappy at gmail.com>>:
>>         2014-02-14 Marco Hugentobler <marco.hugentobler at sourcepole.ch
>>         <mailto:marco.hugentobler at sourcepole.ch>>:
>>             Hi Andrea
>>             >I suspect that QS try always to recalc the box of every
>>             layer.
>>             QGIS server caches layers (up to 100, but that can be
>>             enhanced using the environment variable
>>             MAX_CACHE_LAYERS).  Furthermore, the GetCapabilities
>>             documents are cached (so no recalculation if using FastCGI).
>>         Thanks Marco, you confirmed what I told Andrea.
>>         It would be a good enhancement if caching could be done in a
>>         persitent manner (out of memory). We could consider, in the
>>         future, to use memcache or something similar.
>>         giovanni
>>         _______________________________________________
>>         Qgis-user mailing list
>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Andrea Peri
>>     qwerty àèìòù
>> Giovanni Allegri
>> http://about.me/giovanniallegri
>> Twitter: https://twitter.com/_giohappy_
>> blog: http://blog.spaziogis.it
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch  http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> __________ Information from ESET Mail Security, version of virus
> signature database 9421 (20140213) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature database 9421 (20140213) __________
> http://www.eset.com
Bernhard Ströbl
Anwendungsbetreuer GIS
Kommunale Immobilien Jena
Am Anger 26
07743 Jena
Tel.: 03641 49- 5190
E-Mail: bernhard.stroebl at jena.de
Internet: www.kij.de
Eigenbetrieb der Stadt Jena
Werkleiter: Dr. Götz Blankenburg
__________ Information from ESET Mail Security, version of virus signature database 9422 (20140214) __________
http://www.eset.com
