[Qgis-user] Qgis-server recompute always the layer bbox ?
G. Allegri giohappy at gmail.com
Fri Feb 14 02:06:07 PST 2014
> I have a question in this context (I thought I made ticket but cannot find
> it)
> What is the sense of setting the bounding box in OWS tab if it is always
> calculated to the sum of the bboxes of the layers in the project? IMHO
> setting the bbox in the project properties should override any calculation
> result.
This happens for the combined extent, not for the single layer. In case you
set it in the OWS tab the overall extent isn't calculated.
giovanni
> Background: One of my layers became empty because a user deleted the last
> record thus its bbox was calculated to be the whole earth resulting in QGIS
> server propagating the whole earth as bbox for this project.
> Bernhard
> Am 14.02.2014 10:34, schrieb Marco Hugentobler:
>> Hi Andrea, Giovanni
>> QGIS Server doesn't calculate the bbox itself, but it queries the extent
>> from the layers. So it can be that certain providers calculate the bbox
>> (of course only if the layer / capabilities document is not cached).
>> For a faster startup, having a persistent cache as Giovanni suggested
>> might help.
>> Regards,
>> Marco
>> On 14.02.2014 10:18, G. Allegri wrote:
>>>     I don't understand why the qgis-server eed to calculate always the
>>>     bbox.
>>>     In the server project windows,
>>>     qgis ask for the published bbox.
>>>     Why it don't use it as bbox rather than calculate it on every
>>>     request ?
>>> Marco, correct me if I'm wrong.
>>> QGIS Server doesn't calculate the BBOX, it parses the layers extents
>>> from the .qgs project and then combine them to obtain the entire BBOX.
>>> The only operation it does is reprojecting the extents to WGS84 to
>>> create the EX_GeographicBoundingBox element.
>>> Anyway, in case the project advertises and extent, the combined extent
>>> won't be calculated, so in your case this phase shouldn't be the
>>> bottleneck...
>>> giovanni
>>>     The FastCGI don't help really.
>>>     In a publishing environment every few hour the instances are
>>>     restated to removed zombi process.
>>>     This mean that every few hours the FastCGI are emptied and reloaded.
>>>     A fastcgi environment mean to load 20 instances of QGIS-server and
>>>     every of them do them own elaboration .
>>>     As the bbox calculation for every layer.
>>>     GASP.
>>>     The start could ask about one hours and more.
>>>     Also another problem with the fastcig is that when
>>>     I change something on a project I need to restart to Web instances
>>>     to dismiss the actual project and reload the new.
>>>     So every change in a qgis project need a restart of all proccess
>>>     (20 and so on in a fastcgi enviroment) every with a slow bbox
>>>     calculation phase.
>>>     mmhh...
>>>     2014-02-14 9:13 GMT+01:00 G. Allegri <giohappy at gmail.com
>>>     <mailto:giohappy at gmail.com>>:
>>>         2014-02-14 Marco Hugentobler <marco.hugentobler at sourcepole.ch
>>>         <mailto:marco.hugentobler at sourcepole.ch>>:
>>>             Hi Andrea
>>>             >I suspect that QS try always to recalc the box of every
>>>             layer.
>>>             QGIS server caches layers (up to 100, but that can be
>>>             enhanced using the environment variable
>>>             MAX_CACHE_LAYERS).  Furthermore, the GetCapabilities
>>>             documents are cached (so no recalculation if using FastCGI).
>>>         Thanks Marco, you confirmed what I told Andrea.
>>>         It would be a good enhancement if caching could be done in a
>>>         persitent manner (out of memory). We could consider, in the
>>>         future, to use memcache or something similar.
>>>         giovanni
>>>         _______________________________________________
>>>         Qgis-user mailing list
>>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>     Andrea Peri
>>>     qwerty àèìòù
>>> Giovanni Allegri
>>> http://about.me/giovanniallegri
>>> Twitter: https://twitter.com/_giohappy_
>>> blog: http://blog.spaziogis.it
>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>> Dr. Marco Hugentobler
>> Sourcepole -  Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>> marco.hugentobler at sourcepole.ch  http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
>> __________ Information from ESET Mail Security, version of virus
>> signature database 9421 (20140213) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> http://www.eset.com
> Bernhard Ströbl
> Anwendungsbetreuer GIS
> Kommunale Immobilien Jena
> Am Anger 26
> 07743 Jena
> Tel.: 03641 49- 5190
> E-Mail: bernhard.stroebl at jena.de
> Internet: www.kij.de
> Eigenbetrieb der Stadt Jena
> Werkleiter: Dr. Götz Blankenburg
> __________ Information from ESET Mail Security, version of virus signature
> database 9422 (20140214) __________
> http://www.eset.com
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140214/56365dbd/attachment.html>
