[Qgis-user] Qgis-server recompute always the layer bbox ?
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Fri Feb 14 02:15:49 PST 2014
Hi Giovanni
Yes, right, it was not forgotten but is really added to the top level group.
Regards,
Marco
On 14.02.2014 11:11, G. Allegri wrote:
> Marco, for the root I thought the OWS setting was used [1], while it
> isn't for the groups/layers childs [2]. Is it right?
> giovanni
> [1]
> https://github.com/qgis/QGIS/blob/master/src/mapserver/qgsprojectparser.cpp#L138
> [2]
> https://github.com/qgis/QGIS/blob/master/src/mapserver/qgsprojectparser.cpp#L980
> 2014-02-14 Marco Hugentobler <marco.hugentobler at sourcepole.ch
> <mailto:marco.hugentobler at sourcepole.ch>>:
> Hi Bernhard
> That option was meant to give the webclient a hint where to zoom
> first. But it probably was forgotten in the server and I agree it
> would be good to overwrite the calculated box in the toplevel group.
> Regards,
> Marco
> On 14.02.2014 10:58, Bernhard Ströbl wrote:
> Hi Marco,
> I have a question in this context (I thought I made ticket but
> cannot find it)
> What is the sense of setting the bounding box in OWS tab if it
> is always calculated to the sum of the bboxes of the layers in
> the project? IMHO setting the bbox in the project properties
> should override any calculation result.
> Background: One of my layers became empty because a user
> deleted the last record thus its bbox was calculated to be the
> whole earth resulting in QGIS server propagating the whole
> earth as bbox for this project.
> Bernhard
> Am 14.02.2014 10:34, schrieb Marco Hugentobler:
> Hi Andrea, Giovanni
> QGIS Server doesn't calculate the bbox itself, but it
> queries the extent
> from the layers. So it can be that certain providers
> calculate the bbox
> (of course only if the layer / capabilities document is
> not cached).
> For a faster startup, having a persistent cache as
> Giovanni suggested
> might help.
> Regards,
> Marco
> On 14.02.2014 10:18, G. Allegri wrote:
> I don't understand why the qgis-server eed to
> calculate always the
> bbox.
> In the server project windows,
> qgis ask for the published bbox.
> Why it don't use it as bbox rather than calculate
> it on every
> request ?
> Marco, correct me if I'm wrong.
> QGIS Server doesn't calculate the BBOX, it parses the
> layers extents
> from the .qgs project and then combine them to obtain
> the entire BBOX.
> The only operation it does is reprojecting the extents
> to WGS84 to
> create the EX_GeographicBoundingBox element.
> Anyway, in case the project advertises and extent, the
> combined extent
> won't be calculated, so in your case this phase
> shouldn't be the
> bottleneck...
> giovanni
> The FastCGI don't help really.
> In a publishing environment every few hour the
> instances are
> restated to removed zombi process.
> This mean that every few hours the FastCGI are
> emptied and reloaded.
> A fastcgi environment mean to load 20 instances of
> QGIS-server and
> every of them do them own elaboration .
> As the bbox calculation for every layer.
> GASP.
> The start could ask about one hours and more.
> Also another problem with the fastcig is that when
> I change something on a project I need to restart
> to Web instances
> to dismiss the actual project and reload the new.
> So every change in a qgis project need a restart
> of all proccess
> (20 and so on in a fastcgi enviroment) every with
> a slow bbox
> calculation phase.
> mmhh...
> 2014-02-14 9:13 GMT+01:00 G. Allegri
> <giohappy at gmail.com <mailto:giohappy at gmail.com>
> <mailto:giohappy at gmail.com>>>:
> <mailto:marco.hugentobler at sourcepole.ch>>>:
> Hi Andrea
> >I suspect that QS try always to recalc
> the box of every
> layer.
> QGIS server caches layers (up to 100, but
> that can be
> enhanced using the environment variable
> MAX_CACHE_LAYERS). Furthermore, the
> GetCapabilities
> documents are cached (so no recalculation
> if using FastCGI).
> Thanks Marco, you confirmed what I told Andrea.
> It would be a good enhancement if caching
> could be done in a
> persitent manner (out of memory). We could
> consider, in the
> future, to use memcache or something similar.
> giovanni
> Qgis-user mailing list
> <mailto:Qgis-user at lists.osgeo.org>
> <mailto:Qgis-user at lists.osgeo.org>>
> Andrea Peri
> qwerty àèìòù
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> __________ Information from ESET Mail Security, version of
> virus
> signature database 9421 (20140213) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> virus signature database 9421 (20140213) __________
> http://www.eset.com
> <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
> Giovanni Allegri
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140214/6b09a85e/attachment.html>
