[Qgis-user] Qgis-server recompute always the layer bbox ?
Bernhard Ströbl
bernhard.stroebl at jena.de
Fri Feb 14 03:16:19 PST 2014
Marco,
could you fix this until 2.2 release?
Bernhard
Am 14.02.2014 11:15, schrieb Marco Hugentobler:
> Hi Giovanni
> Yes, right, it was not forgotten but is really added to the top level group.
> Regards,
> Marco
> On 14.02.2014 11:11, G. Allegri wrote:
>> Marco, for the root I thought the OWS setting was used [1], while it
>> isn't for the groups/layers childs [2]. Is it right?
>> giovanni
>> [1]
>> https://github.com/qgis/QGIS/blob/master/src/mapserver/qgsprojectparser.cpp#L138
>> [2]
>> https://github.com/qgis/QGIS/blob/master/src/mapserver/qgsprojectparser.cpp#L980
>> 2014-02-14 Marco Hugentobler <marco.hugentobler at sourcepole.ch
>> <mailto:marco.hugentobler at sourcepole.ch>>:
>> Hi Bernhard
>> That option was meant to give the webclient a hint where to zoom
>> first. But it probably was forgotten in the server and I agree it
>> would be good to overwrite the calculated box in the toplevel group.
>> Regards,
>> Marco
>> On 14.02.2014 10:58, Bernhard Ströbl wrote:
>> Hi Marco,
>> I have a question in this context (I thought I made ticket but
>> cannot find it)
>> What is the sense of setting the bounding box in OWS tab if it
>> is always calculated to the sum of the bboxes of the layers in
>> the project? IMHO setting the bbox in the project properties
>> should override any calculation result.
>> Background: One of my layers became empty because a user
>> deleted the last record thus its bbox was calculated to be the
>> whole earth resulting in QGIS server propagating the whole
>> earth as bbox for this project.
>> Bernhard
>> Am 14.02.2014 10:34, schrieb Marco Hugentobler:
>> Hi Andrea, Giovanni
>> QGIS Server doesn't calculate the bbox itself, but it
>> queries the extent
>> from the layers. So it can be that certain providers
>> calculate the bbox
>> (of course only if the layer / capabilities document is
>> not cached).
>> For a faster startup, having a persistent cache as
>> Giovanni suggested
>> might help.
>> Regards,
>> Marco
>> On 14.02.2014 10:18, G. Allegri wrote:
>> I don't understand why the qgis-server eed to
>> calculate always the
>> bbox.
>> In the server project windows,
>> qgis ask for the published bbox.
>> Why it don't use it as bbox rather than calculate
>> it on every
>> request ?
>> Marco, correct me if I'm wrong.
>> QGIS Server doesn't calculate the BBOX, it parses the
>> layers extents
>> from the .qgs project and then combine them to obtain
>> the entire BBOX.
>> The only operation it does is reprojecting the extents
>> to WGS84 to
>> create the EX_GeographicBoundingBox element.
>> Anyway, in case the project advertises and extent, the
>> combined extent
>> won't be calculated, so in your case this phase
>> shouldn't be the
>> bottleneck...
>> giovanni
>> The FastCGI don't help really.
>> In a publishing environment every few hour the
>> instances are
>> restated to removed zombi process.
>> This mean that every few hours the FastCGI are
>> emptied and reloaded.
>> A fastcgi environment mean to load 20 instances of
>> QGIS-server and
>> every of them do them own elaboration .
>> As the bbox calculation for every layer.
>> GASP.
>> The start could ask about one hours and more.
>> Also another problem with the fastcig is that when
>> I change something on a project I need to restart
>> to Web instances
>> to dismiss the actual project and reload the new.
>> So every change in a qgis project need a restart
>> of all proccess
>> (20 and so on in a fastcgi enviroment) every with
>> a slow bbox
>> calculation phase.
>> mmhh...
>> 2014-02-14 9:13 GMT+01:00 G. Allegri
>> <giohappy at gmail.com <mailto:giohappy at gmail.com>
>> <mailto:giohappy at gmail.com>>>:
>> <mailto:marco.hugentobler at sourcepole.ch>>>:
>> Hi Andrea
>> >I suspect that QS try always to recalc
>> the box of every
>> layer.
>> QGIS server caches layers (up to 100, but
>> that can be
>> enhanced using the environment variable
>> MAX_CACHE_LAYERS). Furthermore, the
>> GetCapabilities
>> documents are cached (so no recalculation
>> if using FastCGI).
>> Thanks Marco, you confirmed what I told Andrea.
>> It would be a good enhancement if caching
>> could be done in a
>> persitent manner (out of memory). We could
>> consider, in the
>> future, to use memcache or something similar.
>> giovanni
>> Qgis-user mailing list
>> <mailto:Qgis-user at lists.osgeo.org>
>> <mailto:Qgis-user at lists.osgeo.org>>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Andrea Peri
>> qwerty àèìòù
>> Giovanni Allegri
>> http://about.me/giovanniallegri
>> Twitter: https://twitter.com/_giohappy_
>> blog: http://blog.spaziogis.it
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>> Dr. Marco Hugentobler
>> Sourcepole - Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>> http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
>> __________ Information from ESET Mail Security, version of
>> virus
>> signature database 9421 (20140213) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> virus signature database 9421 (20140213) __________
>> http://www.eset.com
>> <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
>> Giovanni Allegri
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
__________ Information from ESET Mail Security, version of virus signature database 9423 (20140214) __________
http://www.eset.com
