[Qgis-user] .db and python errors
Drizzle asanch505 at hotmail.com
Sat Feb 15 14:04:22 PST 2014
Hello Quantum Community,
I have installed QGIS 2.01 Dufour on Ubuntu 12.04 LTS.  When Qgis starts
i get a couple of error messages:
the first is:
//Private qgis.db [ERROR] - Can not make qgis.db private copy./ (not
sure exactly what this means)
the second is:
/Python error - Couldn't load plugin processing due an error when
calling its classFactory() method.//
/Traceback (most recent call last):/
/File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 204, in
startPlugin/
/plugins[packageName] = package.classFactory(iface)/
/File "/usr/share/qgis/python/plugins/processing/__init__.py", line 33,
in classFactory/
/return ProcessingPlugin(iface)/
/File "/usr/share/qgis/python/plugins/processing/ProcessingPlugin.py",
line 53, in __init__/
/Processing.initialize()/
/File "/usr/share/qgis/python/plugins/processing/core/Processing.py",
line 127, in initialize/
/Processing.addProvider(RAlgorithmProvider())/
line 75, in addProvider/
/provider.initializeSettings()/
/File
"/usr/share/qgis/python/plugins/processing/r/RAlgorithmProvider.py",
line 51, in initializeSettings/
/ProcessingConfig.addSetting(Setting(self.getDescription(),
RUtils.RSCRIPTS_FOLDER, "R Scripts folder", RUtils.RScriptsFolder()))/
/File "/usr/share/qgis/python/plugins/processing/r/RUtils.py", line 55,
in RScriptsFolder/
/mkdir(folder)/
/File
"/usr/share/qgis/python/plugins/processing/core/ProcessingUtils.py",
line 95, in mkdir/
/mkdir(head)/
/File
line 97, in mkdir/
/os.mkdir(newdir)/
/OSError: [Errno 13] Permission denied:
'/home/huckleberry/.qgis2//processing'/
/Python version:/
/2.7.3 (default, Sep 26 2013, 20:13:52) /
/[GCC 4.6.3]/
/QGIS version:/
/2.0.1-Dufour Dufour, exported/
/Python path: ['/usr/share/qgis/python/plugins/processing',
'/usr/share/qgis/python', '/home/huckleberry/.qgis2/python',
'/home/huckleberry/.qgis2/python/plugins',
'/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
'/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/python2.7/dist-packages/gst-0.10',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
'/usr/lib/python2.7/dist-packages/ubuntuone-couch',
'/usr/lib/python2.7/dist-packages/ubuntuone-installer',
'/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']/
I thought I had installed the python from the terminal prompt when
installing but obviously not : sudo apt-get install qgis python-qgis.
ANY SUGGESTIONS ON HOW TO FIX THESE ERRORS???
Thanks,
A
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140215/fe843593/attachment.html>
