[Qgis-user] .db and python errors
Etienne Tourigny
etourigny.dev at gmail.com
Sat Feb 15 14:11:00 PST 2014
probably happened because you ran qgis as root - or a long-standing bug
with ubuntu...
just remove your /home/huckleberry/.qgis2// folder as root and then run
qgis again (not as root).
sudo rm -rf /home/huckleberry/.qgis2//
On Sat, Feb 15, 2014 at 8:04 PM, Drizzle <asanch505 at hotmail.com> wrote:
> Hello Quantum Community,
> I have installed QGIS 2.01 Dufour on Ubuntu 12.04 LTS. When Qgis starts i
> get a couple of error messages:
> the first is:
> *Private qgis.db [ERROR] - Can not make qgis.db private copy.* (not sure
> exactly what this means)
> the second is:
> *Python error - Couldn't load plugin processing due an error when calling
> its classFactory() method.*
> *Traceback (most recent call last):*
> * File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 204, in
> startPlugin*
> * plugins[packageName] = package.classFactory(iface)*
> * File "/usr/share/qgis/python/plugins/processing/__init__.py", line 33,
> in classFactory*
> * return ProcessingPlugin(iface)*
> * File "/usr/share/qgis/python/plugins/processing/ProcessingPlugin.py",
> line 53, in __init__*
> * Processing.initialize()*
> * File "/usr/share/qgis/python/plugins/processing/core/Processing.py",
> line 127, in initialize*
> * Processing.addProvider(RAlgorithmProvider())*
> line 75, in addProvider*
> * provider.initializeSettings()*
> * File
> "/usr/share/qgis/python/plugins/processing/r/RAlgorithmProvider.py", line
> 51, in initializeSettings*
> * ProcessingConfig.addSetting(Setting(self.getDescription(),
> RUtils.RSCRIPTS_FOLDER, "R Scripts folder", RUtils.RScriptsFolder()))*
> * File "/usr/share/qgis/python/plugins/processing/r/RUtils.py", line 55,
> in RScriptsFolder*
> * mkdir(folder)*
> * File
> "/usr/share/qgis/python/plugins/processing/core/ProcessingUtils.py", line
> 95, in mkdir*
> * mkdir(head)*
> * File
> 97, in mkdir*
> * os.mkdir(newdir)*
> *OSError: [Errno 13] Permission denied:
> '/home/huckleberry/.qgis2//processing'*
> *Python version:*
> *2.7.3 (default, Sep 26 2013, 20:13:52) *
> *[GCC 4.6.3]*
> *QGIS version:*
> *2.0.1-Dufour Dufour, exported*
> *Python path: ['/usr/share/qgis/python/plugins/processing',
> '/usr/share/qgis/python', '/home/huckleberry/.qgis2/python',
> '/home/huckleberry/.qgis2/python/plugins',
> '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
> '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
> '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
> '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']*
> I thought I had installed the python from the terminal prompt when
> installing but obviously not : sudo apt-get install qgis python-qgis.
> ANY SUGGESTIONS ON HOW TO FIX THESE ERRORS???
> Thanks,
> A
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140215/d6392310/attachment.html>
