[Qgis-user] Qgis-server recompute always the layer bbox ?
Andrea Peri
aperi2007 at gmail.com
Sun Feb 16 08:16:39 PST 2014
I found it.
It was defined in the cmake section:
FindSPATIALITE.cmake
Ok, now I procede to understand if it is really checked.
Regards,
A.
2014-02-16 16:58 GMT+01:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> study-ing the qgis code, I see in the spatialite provider there is a
> significative piece of code conditioned by
> some
> #IFDEF SPATIALITE_VERSION_GE_4_0_0
> I don't see any option in cmake setting named like this.
> Is this a missing ?
> Thx,
> A.
> 2014-02-14 10:54 GMT+01:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
>> thx I now start to understand better the question.
>> Infact I'm using spatialite db. A 4.1.1 db spatialite.
>> The spatialite db has an internal statistics table to perform a very fast
>> resolution of the bboxes of single datasets.
>> I always update it using the command:
>> select UpdateLayerStatistics();
>> But the problem is if the client really use that table.
>> Infact I guess more probably the qgis-server don't ask to spatialite the
>> box from this table, but instead do a more usual
>> sql to retrieve is.
>> Hi Sandro,
>> do you know the right query to retrieve the bbox from the statistics
>> table of spatialite 4.1.1 ?
>> I guess suspect that qgis (because it like) to be more compatible with
>> all the oldest (arcaic) version of spatialite, simply avoid to use this
>> table.
>> Many thx.
>> Andrea.
>> 2014-02-14 10:34 GMT+01:00 Marco Hugentobler <
>> marco.hugentobler at sourcepole.ch>:
>> Hi Andrea, Giovanni
>>> QGIS Server doesn't calculate the bbox itself, but it queries the extent
>>> from the layers. So it can be that certain providers calculate the bbox (of
>>> course only if the layer / capabilities document is not cached).
>>> For a faster startup, having a persistent cache as Giovanni suggested
>>> might help.
>>> Regards,
>>> Marco
>>> On 14.02.2014 10:18, G. Allegri wrote:
>>>> I don't understand why the qgis-server eed to calculate always the
>>>> bbox.
>>>> In the server project windows,
>>>> qgis ask for the published bbox.
>>>> Why it don't use it as bbox rather than calculate it on every request
>>> Marco, correct me if I'm wrong.
>>> QGIS Server doesn't calculate the BBOX, it parses the layers extents
>>> from the .qgs project and then combine them to obtain the entire BBOX.
>>> The only operation it does is reprojecting the extents to WGS84 to
>>> create the EX_GeographicBoundingBox element.
>>> Anyway, in case the project advertises and extent, the combined extent
>>> won't be calculated, so in your case this phase shouldn't be the
>>> bottleneck...
>>> giovanni
>>>> The FastCGI don't help really.
>>>> In a publishing environment every few hour the instances are restated
>>>> to removed zombi process.
>>>> This mean that every few hours the FastCGI are emptied and reloaded.
>>>> A fastcgi environment mean to load 20 instances of QGIS-server and
>>>> every of them do them own elaboration .
>>>> As the bbox calculation for every layer.
>>>> GASP.
>>>> The start could ask about one hours and more.
>>>> Also another problem with the fastcig is that when
>>>> I change something on a project I need to restart to Web instances to
>>>> dismiss the actual project and reload the new.
>>>> So every change in a qgis project need a restart of all proccess (20
>>>> and so on in a fastcgi enviroment) every with a slow bbox calculation phase.
>>>> mmhh...
>>>> 2014-02-14 9:13 GMT+01:00 G. Allegri <giohappy at gmail.com>:
>>>>> 2014-02-14 Marco Hugentobler <marco.hugentobler at sourcepole.ch>:
>>>>> Hi Andrea
>>>>>> >I suspect that QS try always to recalc the box of every layer.
>>>>>> QGIS server caches layers (up to 100, but that can be enhanced using
>>>>>> the environment variable MAX_CACHE_LAYERS). Furthermore, the
>>>>>> GetCapabilities documents are cached (so no recalculation if using
>>>>>> FastCGI).
>>>>> Thanks Marco, you confirmed what I told Andrea.
>>>>> It would be a good enhancement if caching could be done in a persitent
>>>>> manner (out of memory). We could consider, in the future, to use memcache
>>>>> or something similar.
>>>>> giovanni
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Andrea Peri
>>>> qwerty àèìòù
>>> Giovanni Allegri
>>> http://about.me/giovanniallegri
>>> Twitter: https://twitter.com/_giohappy_
>>> blog: http://blog.spaziogis.it
>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>>> Dr. Marco Hugentobler
>>> Sourcepole - Linux & Open Source Solutions
>>> Weberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>> Technical Advisor QGIS Project Steering Committee
>> Andrea Peri
>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140216/8bf82cfc/attachment.html>
