[Qgis-user] Project not loading in web client
Bernhard Ströbl bernhard.stroebl at jena.de
Mon Feb 17 23:53:40 PST 2014
Hi Voytek,
is the QWC on a publicly available server?
If no could you post the GetProjectSettings xml?
To further dig into you could check the GetMap request QWC issues
(either with firebug or on apache's acces log)
Bernhard
Am 18.02.2014 07:43, schrieb Voytek Lapinski:
> Hi Bernhard,
> Thanks for the response. I have, yes.
> Since my first email I have also tried to do it using a simpler project
> as you suggest. It has only a single layer, using a shapefile. That
> fails in the same way, after a successful GetProjectSettings.
> -voytek
> On 18/02/14 17:33, Bernhard Ströbl wrote:
>> Hi Voytek,
>> have you configured your QWC (especially GlobalOption.js) as described
>> in https://github.com/qgis/QGIS-Web-Client/blob/master/README ?
>> I would suggest to create a project with just one layer and get that
>> running.
>> Bernhard
>> Am 18.02.2014 05:44, schrieb Voytek Lapinski:
>>> Hi All,
>>> I am experiencing a problem on a new ubuntu/apache installation of the
>>> web client, where a project file is causing the web client to fail after
>>> loading the layers, but before drawing a map.
>>> The problem is similar to
>>> http://osgeo-org.1560.x6.nabble.com/Problem-loading-map-using-QGIS-web-client-on-Windows-7-td5029267.html
>>> , which I've worked through to no avail.
>>> The GetProjectSettings call to the server from the web client seems to
>>> work fine, and generates a valid looking result when I call it directly.
>>> The web client shows the layers returned in the layer list sidebar, but
>>> never generates a GetMap call. Am I right in thinking that this should
>>> be the next step?
>>> The last HTTP request from the webclient is to the googleapis
>>> Authentication Service which seems strange as that map doesn't use
>>> anything from Google. After that it just stays on the message 'Loading
>>> Map'.
>>> There are no error messages in the apache log, apart from the following
>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>> environment variable.
>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>> Am I right in believing that that these shouldn't cause failure,
>>> however?
>>> I am able to load the demonstration examples (HelloWorld and
>>> NaturalEarth) in the web client with no issues, so am assuming it's
>>> something to do with my particular project. The project itself loads
>>> fine in QGIS on the desktop machine I created it on. The desktop and
>>> server are both ubuntu 12.04, and are identical, from the point of view
>>> of GIS system software. Qgis desktop and server is 2.0. Postgis is 2.1.
>>> The web client is the most recent version from the git repository. All
>>> the project layers are stored in local postgis databases (version 2.1 on
>>> postgres 9.3) replicated on both machines exactly.
>>> It seems like it should be something straightforward to do with the
>>> project, but in the absence of any useful error or log messages, I don't
>>> really know where to start.
>>> Any help would be much appreciated.
>>> -voytek
__________ Information from ESET Mail Security, version of virus signature database 9436 (20140217) __________
The message was checked by ESET Mail Security.
http://www.eset.com
