[Qgis-user] Project not loading in web client
Voytek Lapinski
voytekl at octobit.com.au
Tue Feb 18 16:31:37 PST 2014
CC'ing back to the list, in case this can help someone down the track
through the list archive.
Thanks for the help Bernhard. I got there in the end.
The CRS mismatch (as described below) wasn't actually causing the
problem, although it did cause other issues if I got the map to load.
The problem with the map not loading was being caused by not having the
"Service Capabilities" box checked in Project Properties/OWS Server.
Once that's turned on, the project loads fine in the web client (albeit
with other issues unless the CRS stuff is sorted out also). Rookie
mistake, obviously.
Thanks again.
-voytek
-------- Original Message --------
Subject: Re: [Qgis-user] Project not loading in web client
Date: Wed, 19 Feb 2014 10:27:08 +1100
To: Bernhard Ströbl <bernhard.stroebl at jena.de>
Hi Bernhard,
Aah, ok. I didn't realise the client and the project had to match,
figuring it would re-project if it had to.
I've tried your suggestions, changing everything to EPSG:4283 which is
the CRS I will need to use. There was no EPSG4283.js in
/site/libs/proj4js so created one using the flags for that CRS shown in
the QGIS desktop (should this work?). I still had the same behaviour.
At this point I thought it might be something to do with EPSG4283, so I
tried changing everything to EPSG3857 (including converting the source
data) as I know that works for the example projects. It still doesn't
work though. Failure mode is the same as before.
This is the version with everything in EPSG3857 if you want to have a look:
http://xxxxxx/qgiswebclient.html?map=/usr/local/share/qgis-web-client/projects/testshape3857.qgs
Thanks for your help with this!
--voytek
On 18/02/14 19:55, Bernhard Ströbl wrote:
> line 180 of your Globaloptions.js reads
> var authid = "EPSG:"+3857;
> is this the projection of the QGIS project?
> try:
> - set the projection of the project the same as the projection of your
> data (performance)
> - change line 180 of Globaloptions.js accordingly
> - and IMPORTANT: open project-properties OWS-Server, input data there
> and especially limit the CRS to the CRS you set for the project.
> Bernhard
> Am 18.02.2014 09:35, schrieb Voytek Lapinski:
>> You can see the behaviour at:
>> http://xxxxx/qgiswebclient.html?map=/usr/local/share/qgis-web-client/projects/testshape.qgs
>> and the GetProjectSettings xml at:
>> http://xxxx/cgi-bin/qgis_mapserv.fcgi?map=/usr/local/share/qgis-web-client/projects/testshape.qgs&&_dc=1392711137396&SERVICE=WMS&VERSION=1.3&REQUEST=GetProjectSettings
>> I'm not sure what you mean by checking getmap request issues. If I
>> understand you correctly though, it's not actually making any getmap
>> requests. I've checked both firebug and the apache logs. Firebug
>> generally shows only these two requests after initial page load.
>> http://xxxx/cgi-bin/qgis_mapserv.fcgi?map=/usr/local/share/qgis-web-client/projects/testshape.qgs&&_dc=1392711943007&SERVICE=WMS&VERSION=1.3&REQUEST=GetProjectSettings
>> https://maps.googleapis.com/maps/api/js/AuthenticationService.Authenticate?1shttp%3A%2F%2Fgistest.octobit.com.au%2Fqgiswebclient.html%3Fmap%3D%2Fusr%2Flocal%2Fshare%2Fqgis-web-client%2Fprojects%2Ftestshape.qgs&5e1&callback=_xdc_._hvx0uq&token=34217
>> The second one seems strange, as I'm not using any google data in the
>> project. Occasionally you see it call some other stuff from
>> maps.googleapis.com which returns a 204, but I'm having trouble
>> recreating that now. Is it something to do with this maybe?
>> Sorry, it's probably something stupid I'm doing when setting up the
>> project (I'm new to QGIS). But I can't for the life of me work out what
>> it could be.
>> -voytek
>> On 18/02/14 18:53, Bernhard Ströbl wrote:
>>> Hi Voytek,
>>> is the QWC on a publicly available server?
>>> If no could you post the GetProjectSettings xml?
>>> To further dig into you could check the GetMap request QWC issues
>>> (either with firebug or on apache's acces log)
>>> Bernhard
>>> Am 18.02.2014 07:43, schrieb Voytek Lapinski:
>>>> Hi Bernhard,
>>>> Thanks for the response. I have, yes.
>>>> Since my first email I have also tried to do it using a simpler
>>>> project
>>>> as you suggest. It has only a single layer, using a shapefile. That
>>>> fails in the same way, after a successful GetProjectSettings.
>>>> -voytek
>>>> On 18/02/14 17:33, Bernhard Ströbl wrote:
>>>>> Hi Voytek,
>>>>> have you configured your QWC (especially GlobalOption.js) as
>>>>> described
>>>>> in https://github.com/qgis/QGIS-Web-Client/blob/master/README ?
>>>>> I would suggest to create a project with just one layer and get that
>>>>> running.
>>>>> Bernhard
>>>>> Am 18.02.2014 05:44, schrieb Voytek Lapinski:
>>>>>> Hi All,
>>>>>> I am experiencing a problem on a new ubuntu/apache installation
>>>>>> of the
>>>>>> web client, where a project file is causing the web client to fail
>>>>>> after
>>>>>> loading the layers, but before drawing a map.
>>>>>> The problem is similar to
>>>>>> http://osgeo-org.1560.x6.nabble.com/Problem-loading-map-using-QGIS-web-client-on-Windows-7-td5029267.html
>>>>>> , which I've worked through to no avail.
>>>>>> The GetProjectSettings call to the server from the web client
>>>>>> seems to
>>>>>> work fine, and generates a valid looking result when I call it
>>>>>> directly.
>>>>>> The web client shows the layers returned in the layer list sidebar,
>>>>>> but
>>>>>> never generates a GetMap call. Am I right in thinking that this
>>>>>> should
>>>>>> be the next step?
>>>>>> The last HTTP request from the webclient is to the googleapis
>>>>>> Authentication Service which seems strange as that map doesn't use
>>>>>> anything from Google. After that it just stays on the message
>>>>>> 'Loading
>>>>>> Map'.
>>>>>> There are no error messages in the apache log, apart from the
>>>>>> following
>>>>>> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
>>>>>> environment variable.
>>>>>> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
>>>>>> Am I right in believing that that these shouldn't cause failure,
>>>>>> however?
>>>>>> I am able to load the demonstration examples (HelloWorld and
>>>>>> NaturalEarth) in the web client with no issues, so am assuming it's
>>>>>> something to do with my particular project. The project itself loads
>>>>>> fine in QGIS on the desktop machine I created it on. The desktop and
>>>>>> server are both ubuntu 12.04, and are identical, from the point of
>>>>>> view
>>>>>> of GIS system software. Qgis desktop and server is 2.0. Postgis is
>>>>>> 2.1.
>>>>>> The web client is the most recent version from the git
>>>>>> repository. All
>>>>>> the project layers are stored in local postgis databases (version
>>>>>> 2.1 on
>>>>>> postgres 9.3) replicated on both machines exactly.
>>>>>> It seems like it should be something straightforward to do with the
>>>>>> project, but in the absence of any useful error or log messages, I
>>>>>> don't
>>>>>> really know where to start.
>>>>>> Any help would be much appreciated.
>>>>>> -voytek
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 9436 (20140217) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140219/99164901/attachment.html>
