[Qgis-user] raster files
Brandon Louw
louw at stjohnscollege.co.za
Tue Feb 18 05:06:14 PST 2014
I have recently download QGIS DuFour on my Macbook pro. I use Raster files in MrSid format and the file can be read but the .sdw file is not read so I am not able to draw in the coordinates in composer. The raster file is georeferenced WGS84 but when I load it I get the following message: The layer appears to have no projection specification. I then set the CRS to WGS84 EPSG:4326 and activate and enable “on the fly". This is a raster toposheet for South Africa. Raster file has the following georeference: Projection Latitude/Longitude Datum:WGS 84. I am able to draw in the coordinates when I use ArcView. I suspect that the .sdw file that is in the folder with the .sid file is not being read when I add the raster layer. Does anyone have a solution to this problem. When I try other CRS settings the coordinates are incorrect. The odd thing is that when I use the Google Earth plugin the raster is snapped to the correct position and the raster image matches up with the google image and gives a 3D image.
Regards,
[cid:49509A89-8495-4FD9-A760-A0982D036A82]
[cid:F2C0D678-7A9D-4E15-97FE-F663DEE44085]
Emails belong in computers, trees belong in forests. If you must print this, please do it on recycled paper.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140218/5cd82788/attachment.html>
Type: image/png
Desc: 1EBF269A-6F1A-4EB2-A04A-2D2C1FDE3327[5].png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140218/5cd82788/attachment.png>
Type: image/png
Desc: AC0F4E70-EE38-438E-9BED-E4064520C75D[5].png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140218/5cd82788/attachment-0001.png>
