[Qgis-user] Problem saving an image w/annotated notes?
Mike Keelan tmike.elhoa at comcast.net
Wed Feb 19 18:48:12 PST 2014
This program is amazingly complex.  As a a new beginner with this SW I
have not figured out how to get my project into the print composer.
Even the support instructions look like they are written for a rocket
scientist.  I can appreciate the flexibility that is apparent, but it is
a steep learning curve.
So, do I have to rebuild the entire project in the composer, or is there
a way to make an import into a new composure as a single operation?
Still learning,  Mike K
On 2/19/2014 9:21 PM, Alex Mandel wrote:
> On 02/19/2014 05:09 PM, Mike Keelan wrote:
>> Hi List,
>> After completing a project with a LOT of annotated notes, (using Qgis
>> 2.0.1, windows 8), I thought I could "save as image".  This function
>> does save all but the annotated notes.  It appears that the notes are on
>> a separate file which does me no good at all.  Is there a different file
>> type that will capture the intire image?  I tried .jpg and .tif.
>> I could use my print screen program but am afraid I would lose a lot of
>> resolution when the image is printed on a larger size.  I need to give
>> it to Staples so they can blow it up to 11"x 17" on waterproof paper.
>> What I'm I missing?  Can any one help?
>> Mike K
> What about from the print composer? as perhaps a PDF?
> I usually make a point layer with data defined label positions so they
> will show up everywhere.
> Enjoy,
> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140219/75adf101/attachment.html>
