[Qgis-user] Problem saving an image w/annotated notes?
Alex Mandel
tech_dev at wildintellect.com
Wed Feb 19 21:14:09 PST 2014
The print composer is a tool to help you print the map view.
Basic steps, open your project, click on the print composer tool.
In the print composer view "add new map", draw a rectangle on the page
and your map view should show up.
See http://qgis.org/en/docs/user_manual/print_composer/print_composer.html
Thanks,
Alex
On 02/19/2014 06:48 PM, Mike Keelan wrote:
> This program is amazingly complex. As a a new beginner with this SW I
> have not figured out how to get my project into the print composer.
> Even the support instructions look like they are written for a rocket
> scientist. I can appreciate the flexibility that is apparent, but it is
> a steep learning curve.
> So, do I have to rebuild the entire project in the composer, or is there
> a way to make an import into a new composure as a single operation?
> Still learning, Mike K
> On 2/19/2014 9:21 PM, Alex Mandel wrote:
>> On 02/19/2014 05:09 PM, Mike Keelan wrote:
>>> Hi List,
>>> After completing a project with a LOT of annotated notes, (using Qgis
>>> 2.0.1, windows 8), I thought I could "save as image". This function
>>> does save all but the annotated notes. It appears that the notes are on
>>> a separate file which does me no good at all. Is there a different file
>>> type that will capture the intire image? I tried .jpg and .tif.
>>> I could use my print screen program but am afraid I would lose a lot of
>>> resolution when the image is printed on a larger size. I need to give
>>> it to Staples so they can blow it up to 11"x 17" on waterproof paper.
>>> What I'm I missing? Can any one help?
>>> Mike K
>> What about from the print composer? as perhaps a PDF?
>> I usually make a point layer with data defined label positions so they
>> will show up everywhere.
>> Enjoy,
>> Alex
> Qgis-user mailing list
