[Qgis-user] Problem saving an image w/annotated notes?
ELHOA
tmike.elhoa at comcast.net
Thu Feb 20 08:50:37 PST 2014
Thanks Alex,
Save image from the composer does capture all the annotated info, and at 300dpi the resolution is good. It can be saved as jpg, tif or any number of other file types. There are some alignment issues but I can work on it.
Mike K
Sent from my iPhone
> On Feb 20, 2014, at 12:14 AM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> The print composer is a tool to help you print the map view.
> Basic steps, open your project, click on the print composer tool.
> In the print composer view "add new map", draw a rectangle on the page
> and your map view should show up.
> See http://qgis.org/en/docs/user_manual/print_composer/print_composer.html
> Thanks,
> Alex
>> On 02/19/2014 06:48 PM, Mike Keelan wrote:
>> This program is amazingly complex. As a a new beginner with this SW I
>> have not figured out how to get my project into the print composer.
>> Even the support instructions look like they are written for a rocket
>> scientist. I can appreciate the flexibility that is apparent, but it is
>> a steep learning curve.
>> So, do I have to rebuild the entire project in the composer, or is there
>> a way to make an import into a new composure as a single operation?
>> Still learning, Mike K
>>> On 2/19/2014 9:21 PM, Alex Mandel wrote:
>>>> On 02/19/2014 05:09 PM, Mike Keelan wrote:
>>>> Hi List,
>>>> After completing a project with a LOT of annotated notes, (using Qgis
>>>> 2.0.1, windows 8), I thought I could "save as image". This function
>>>> does save all but the annotated notes. It appears that the notes are on
>>>> a separate file which does me no good at all. Is there a different file
>>>> type that will capture the intire image? I tried .jpg and .tif.
>>>> I could use my print screen program but am afraid I would lose a lot of
>>>> resolution when the image is printed on a larger size. I need to give
>>>> it to Staples so they can blow it up to 11"x 17" on waterproof paper.
>>>> What I'm I missing? Can any one help?
>>>> Mike K
>>> What about from the print composer? as perhaps a PDF?
>>> I usually make a point layer with data defined label positions so they
>>> will show up everywhere.
>>> Enjoy,
>>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
