[Qgis-user] QGIS with digitizing board/tablet
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Fri Feb 21 03:21:03 PST 2014
Tom -
A few pointer to a more productive environment:
  * (As we already agreed upon) No paper maps and digitizers: Scan the
    maps and use a mouse and monitor
  * Get the largest monitor to the digitizing operation your budget will
    allow (24 " or 27" is nice).
  * Whatever you are using QGIS, MapInfo or ArcGis (or whatever): Make a
    row or two with buttons, where the separate button activate some
    kind of desired function when digitizing. The digitizing user should
    not need to go looking for digitizing functionality in obscure
    places in the user interface. Be aware, that the only way to survive
    mind-numbing work as digitizing, is to "switch off" the brain. That
    means you have to design the user interface accordingly.
  * The work-flow should include that the digitizer user always make a
    backup-copy of the original material before starting new digitizing.
  * Save often/early.
It might sound like a lesson "101" (and it is) but a lot of people seem
to forget it.
Regards
Bo Vctor Thomsen
Aestas-GIS
Denmark
Den 21-02-2014 11:57, Thomas Colley skrev:
> I agree with you 100% on georeferencing scanned rasters being a much
> better option! There wouldn't even be any cost to the scanning as we
> have a large format scanner and many of the plans are electronic
> anyway meaning they would have to be printed off to be put onto the
> board and digitised!
> I thought that maybe I was missing something as I'm not from a
> hardcore drawing background as the users were maintaining that they
> needed to use the boards even when I showed them the excellent
> Georeferencer in QGIS. It sounds like this might just be an excuse for
> them not wanting to move away from ArcGIS!
> Thanks very much for your reply
> Tom
> *From:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Bo Victor
> Thomsen
> *Sent:* 21 February 2014 09:03
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] QGIS with digitizing board/tablet
> To Thomas -
> It would probably not be exceedingly difficult to create a plugin that
> would let a digitizing board work with QGIS.
> But just my 2 cents as an old digitizing monkey way back in history:
> Productivity- and operation wise, it's a far better deal to scan your
> maps - whatever size they have - at your local printing shop and then
> georeference the rasterfile(s) once and for all. Trust me: It will
> beat the digitizer setup almost all the time - even when you include
> the cost of scanning the maps at a printing shop.
> Regards
> Bo Victor Thomsen
> Aestas-GIS
> Denmark
> Den 21-02-2014 08:56, Thomas Colley skrev:
>     Hi Nathan
>     Thanks for replying. From what I can understand it's just a case
>     of georeferencing the drawing on the board in the same way as you
>     would a raster on the screen.
>     ArcMap takes a text file with at least 4 coordinate pairs from the
>     drawing on the board that it uses to tie the digitizing area into
>     the on screen CRS.
>     So I hope it might be relatively easy to implement a plugin that
>     can accept these coordinates then apply some sort of shift to any
>     input from the drawing board.
>     I'll try and get some more info on how it works in ArcMap.
>     Thanks again
>     Tom
>     *From:*Nathan Woodrow [mailto:madmanwoo at gmail.com]
>     *Sent:* 20 February 2014 12:54
>     *To:* Thomas Colley
>     *Cc:* qgis-user
>     Hey Thomas,
>     Wouldn't it just pick it up like a mouse?  Qt does have support
>     for more pressure based devices but QGIS doesn't take advantage of
>     it.   It will work fine if it acts like a mouse though.
>     - Nathan
>     On Thu, Feb 20, 2014 at 10:50 PM, Thomas Colley
>     <t.colley at neath-porttalbot.gov.uk
>     <mailto:t.colley at neath-porttalbot.gov.uk>> wrote:
>     Hi
>     Is it possible to use QGIS with a digitizing board/tablet?
>     I've had a search but can't find any information on this.
>     The board I am trying to use is a CalComp DrawingBoard III that
>     our users have been using with ArcMap.
>     If it's not currently possible in QGIS I will look at creating a
>     plugin for it.
>     Thanks
>     Tom
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140221/619431ad/attachment.html>
