[Qgis-user] qgis-bin.exe - Entry Point Not Found
Minoru Akagi
akaginch at gmail.com
Sun Feb 23 03:07:42 PST 2014
Since not far from the source code release, it ought to still be test
period of the binary release. OSGeo4W 32-bit installation (with Exp
selected in installer) works without start-up error, but 64-bit app is
blocked with the error. The qgis package of 64-bit seems to lack core dlls
(dlls in qgis/bin). Looking forward to stable release!!
Thanks,
Minoru
2014-02-23 19:04 GMT+09:00 Lester Anderson <arctica1963 at gmail.com>:
> Hopefully they will correct these install issues before releasing the
> standalone Windows installer! v2.0.1 had that annoying run-time issue at
> start-up (but did not stop functionality).
> In theory, you should be able to install multiple versions of QGIS as I
> think they go into separate folder structures. I seem to recall seeing a
> similar message to the one you had but with 1.8.0, not sure what caused it
> as it was after the program was running.
> I am waiting until the site is formally updated before attempting to
> install
> On 23 February 2014 06:08, James Wood <jwood911 at gmail.com> wrote:
>> Newbie with respect to installing via the OSGeo4W installer. Using the
>> Network 64bit Installer from the downloads page and choosing Desktop
>> Express Setup, the installation completes successfully (QGIS, GDAL, GRASS).
>> When I try to open QGIS Desktop 2.2.0 from my OSGeo4W program group I
>> receive the following error message:
>> Typing "qgis.bat" from the shell produces the same error.
>> A quick online search returned some similar error messages which were
>> solved by copying DLLs to the ..\apps\qgis\bin folder, but I'm not sure
>> what to copy if anything given the error message.
>> I'm running Windows 7 SP1, x64, 2.4GHz with 8GB RAM. I previously had
>> QGIS 2.0.1 installed, which I uninstalled before running the
>> OSGeo4W setup. MSYS, SAGA GIS (2.0.8) and GRASS (6.4.3), which were
>> installed with the setup, all open fine. Any help would be appreciated...
>> Best Regards,
>> James
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140223/85b26988/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140223/85b26988/attachment.png>
