[Qgis-user] qgis-bin.exe - Entry Point Not Found
Lester Anderson arctica1963 at gmail.com
Sun Feb 23 02:04:53 PST 2014
Hopefully they will correct these install issues before releasing the
standalone Windows installer! v2.0.1 had that annoying run-time issue at
start-up (but did not stop functionality).
In theory, you should be able to install multiple versions of QGIS as I
think they go into separate folder structures. I seem to recall seeing a
similar message to the one you had but with 1.8.0, not sure what caused it
as it was after the program was running.
I am waiting until the site is formally updated before attempting to install
On 23 February 2014 06:08, James Wood <jwood911 at gmail.com> wrote:
>  Newbie with respect to installing via the OSGeo4W installer. Using the
> Network 64bit Installer from the downloads page and choosing Desktop
> Express Setup, the installation completes successfully (QGIS, GDAL, GRASS).
> When I try to open QGIS Desktop 2.2.0 from my OSGeo4W program group I
> receive the following error message:
> Typing "qgis.bat" from the shell produces the same error.
> A quick online search returned some similar error messages which were
> solved by copying DLLs to the ..\apps\qgis\bin folder, but I'm not sure
> what to copy if anything given the error message.
> I'm running Windows 7 SP1, x64, 2.4GHz with 8GB RAM. I previously had QGIS
> 2.0.1 installed, which I uninstalled before running the
> OSGeo4W setup.  MSYS, SAGA GIS (2.0.8) and GRASS (6.4.3), which were
> installed with the setup, all open fine. Any help would be appreciated...
> Best Regards,
> James
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140223/b358086d/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140223/b358086d/attachment.png>
