[Qgis-user] Raster Calculator - If statements
Carlos Cerdán
sig.upagu at gmail.com
Mon Feb 24 11:47:23 PST 2014
Hi Jonathan:
As I said, this works band by band... so I think maybe you would can do:
ZERO For Band 1 : (band1 at 1<=145 and band2 at 1<=145 and band3 at 1<=145)*band1 at 1
ZERO For Band 2 : (band1 at 1<=145 and band2 at 1<=145 and band3 at 1<=145)*band2 at 1
ZERO For Band 3 : (band1 at 1<=145 and band2 at 1<=145 and band3 at 1<=145)*band3 at 1
NULL For Band 1 : ( ((band1 at 1<=145 and band2 at 1<=145 and band3 at 1<=145)*band1 at 1)
/ ((band1 at 1<=145 and band2 at 1<=145 and band3 at 1<=145)*band1 at 1) ) * band1 at 1
NULL For Band 2 : ( ((band1 at 1<=145 and band2 at 1<=145 and band3 at 1<=145)*band2 at 1)
/ ((band1 at 1<=145 and band2 at 1<=145 and band3 at 1<=145)*band2 at 1) ) * band2 at 1
NULL For Band 3 : ( ((band1 at 1<=145 and band2 at 1<=145 and band3 at 1<=145)*band3 at 1)
/ ((band1 at 1<=145 and band2 at 1<=145 and band3 at 1<=145)*band3 at 1) ) * band3 at 1
After that, you'll must have to merge this bands (Raster-->Miscellany -->
Merge )
Good Luck
Carlos
2014-02-24 9:30 GMT-05:00 Jonathan Moules <
jonathanmoules at warwickshire.gov.uk>:
> Hi Carlos,
> Thanks for your thoughts. One observation - it appears that you are only
> checking a single band at a time.
> However I only want the values to be changed if ALL bands have a value of
> >145. If only one or even two of the values are >145 then nothing should be
> changed, it's only when all three are that I want it to be triggered.
> That makes the problem even more tricky. :-)
> Kind Regards,
> Jonathan
> On 21 February 2014 21:40, Carlos Cerdán <sig.upagu at gmail.com> wrote:
>> Hi Jonathan:
>> Interesting puzzle. You can get what you wish if you use GRASS (r.mapcalc
>> and r.null). With QGIS I just got zero or null, but band by band:
>> ZERO : (band1 at 1<=145)*band1 at 1
>> NULL : ( ((band1 at 1<=145)*band1 at 1) / ((band1 at 1<=145)*band1 at 1) ) * band1 at 1
>> Explanation:
>> 1. ZERO: When condition in parenthesis is true, it goes 1, if doesn't, 0.
>> After that, multiply by the same band, so result is 0 in cells that
>> original value was major than 145, and it's the same value as original in
>> other cells.
>> 2. NULL: We have same prior value divided by himself. In cells where we
>> got 0, now will get NULL, and the original value in other cells.
>> I used 145 according your example.
>> Good luck
>> Carlos
>> 2014-02-21 8:37 GMT-05:00 Jonathan Moules <
>>> Hi List,
>>> I have a three band raster. I want to do the following with:
>>> If (Band1 > 150 AND Band2 > 150 AND Band3 > 150){
>>>> Band1 = 255
>>>> Band1 = 255
>>>> Band1 = 255
>>> Basically set all band values to 255 when all band values are > than a
>>> value of 150. All other band values should remain unchanged.
>>> How do I do this? I've got as far as the below for the :
>>>> ( "CR0569TEI_00008_modified at 1" > 145 AND "CR0569TEI_00008_modified at 2"
>>>> > 145 AND "CR0569TEI_00008_modified at 3" > 145 )
>>> But am unsure what's next. The tutorials I've found online assume I only
>>> want 1 or 0 as my results.
>>> Help welcome. :-)
>>> Thanks,
>>> Jonathan
>>> This transmission is intended for the named addressee(s) only and may
>>> contain sensitive or protectively marked material up to RESTRICTED and
>>> should be handled accordingly. Unless you are the named addressee (or
>>> authorised to receive it for the addressee) you may not copy or use it, or
>>> disclose it to anyone else. If you have received this transmission in error
>>> please notify the sender immediately. All email traffic sent to or from us,
>>> including without limitation all GCSX traffic, may be subject to recording
>>> and/or monitoring in accordance with relevant legislation.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140224/fa7c0240/attachment.html>
