[Qgis-user] r.drain result not showing
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Feb 25 00:42:11 PST 2014
How is it in 2.2? It sounds like it may be a regression; in which case I'd
report it as a bug.
Cheers,
Jonathan
On 21 February 2014 18:30, Gerardo Jiménez <gejst5 at gmail.com> wrote:
> Hello
> I ran r.cost and r.walk from qgis(qgis 2.01 64 bits standallone
> instalation on win7 64 16gb of RAM) . When I run r.drain all I have is a
> big black square. The resulting path is there since I am able to convert to
> vector and see the path. When i do the same wit qgis lisboa I do get the
> raster path. Any Ideas are welcome
> Thanks before hand
> Gerardo
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/5ef04257/attachment.html>
