[Qgis-user] Plugin - draw a circle and measure
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Feb 25 03:52:34 PST 2014
Hi List,
I was wondering, is there a plugin that would allow the digitisation of a
circle, but during the digitisation would also show the user the radius of
the circle?
This way a user can draw a circle of 500m (or whatever) radius easily.
Could also potentially be useful for other shapes.
I've dabbled with the plugins and there's certainly one for digitising
circles, but none does the measuring as best I can see. Is there one I'm
missing?
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/57b79fc0/attachment.html>
