[Qgis-user] Plugin - draw a circle and measure
McDonaldR McDonaldR at angus.gov.uk
Tue Feb 25 04:40:51 PST 2014
Hi Jonathan
I was looking at the same problem a couple of weeks ago and the closest I came was using a buffer round a point where I could specify the radius.
I logged a feature request with the developer through github for the Rect Oval Digitising Plugin asking for exactly that - https://github.com/vinayan/RectOvalDigitPlugin/issues/1
If I was up to speed on Python I'd give it a go...
Cheers
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk> | W: Angus Maps<http://www.angus.gov.uk/maps/map_home.cfm>
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jonathan Moules
Sent: 25 February 2014 11:53
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Plugin - draw a circle and measure
Hi List,
I was wondering, is there a plugin that would allow the digitisation of a circle, but during the digitisation would also show the user the radius of the circle?
This way a user can draw a circle of 500m (or whatever) radius easily.
Could also potentially be useful for other shapes.
I've dabbled with the plugins and there's certainly one for digitising circles, but none does the measuring as best I can see. Is there one I'm missing?
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons.  Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/6142d29d/attachment.html>
