[Qgis-user] Plugin - draw a circle and measure
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Feb 25 04:51:13 PST 2014
Hi Ross,
Thanks for pointing that out. I've added my +1 to it.
I'm passable with Python but looking at the code there's too much Object
Oriented for my liking; plus I don't know the QGIS API.
Cheers,
Jonathan
On 25 February 2014 12:40, McDonaldR <McDonaldR at angus.gov.uk> wrote:
>    Hi Jonathan
> I was looking at the same problem a couple of weeks ago and the closest I
> came was using a buffer round a point where I could specify the radius.
> I logged a feature request with the developer through github for the Rect
> Oval Digitising Plugin asking for exactly that -
> https://github.com/vinayan/RectOvalDigitPlugin/issues/1
> If I was up to speed on Python I'd give it a go...
> Cheers
> Ross
> *Ross McDonald *| GIS Data Coordinator | Resources Department, IT
> Division | Angus Council, Angus House, Orchardbank Business Park, Forfar,
> DD8 1AT
> T: *01307 476419* | F: 01307 476401 | E: mcdonaldr at angus.gov.uk | W: *Angus
> Maps <http://www.angus.gov.uk/maps/map_home.cfm>*
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Jonathan Moules
> *Sent:* 25 February 2014 11:53
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Plugin - draw a circle and measure
> Hi List,
> I was wondering, is there a plugin that would allow the digitisation of a
> circle, but during the digitisation would also show the user the radius of
> the circle?
> This way a user can draw a circle of 500m (or whatever) radius easily.
> Could also potentially be useful for other shapes.
> I've dabbled with the plugins and there's certainly one for digitising
> circles, but none does the measuring as best I can see. Is there one I'm
> missing?
> Cheers,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons.  Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/a791e025/attachment.html>
