[Qgis-user] Simple Url-Rewriting for the web-client
Gunnar Oehmichen
oehm8895 at uni-landau.de
Tue Feb 25 08:00:42 PST 2014
Hello there,
I am trying to approach the problem of url-rewriting for the
qgis-webclient for the first time. For safety purposes I am testing this
on a virtual machine with the enabled site (localhost) registered in
/etc/hosts/. Directory within which the web-client is located:
/home/guna/www/test.de/
(Ubuntu 12.04)
The original url I inserted as a link into an index.html to direct the
user to the webclient is working just fine:
qgiswebclient.html?map=/home/guna/www/test.de/projects/Solarpot_suew2014_3857_2.qgs
As far as I understand the documentation suggests to me to shorten the
url to the following, which I did
/maps/Solarpot_suew2014_3857_2.qgs
(link-tag: <li class="map-item"><a
href="/maps/Solarpot_suew2014_3857_2.qgs">
Solarpotential Bornheim</a></li> )
But following the link gets me a 404 not found error (probably not
surprising at all).
I thought the following Rule to be sufficient, eg just rewriting
http://test.de/maps/Solarpot_suew2014_3857_2.qgs to
<Directory /home/guna/www/test.de/site/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
RewriteEngine On
# Rewrite /maps/mapname to map url
RewriteRule ^/maps/(.+)$
qgiswebclient.html?map=/home/guna/www/test.de/projects/$1.qgs [PT]
</Directory>
Questions:
1.) Within the qgis-web-client.conf rewriting rules are already provided.
-> Do I need to insert these into the Directory tags ( <Directory
/home/guna/www/test.de/site/> ... </Directory>) preceded by a
RewriteEngine ON? Or should I leave the rules where they allready are?
2.) Since there are two directory tags <Directory
/home/guna/www/test.de/site/> and <Directory
"/home/guna/www/test.de/cgi-bin/"> Which of the provided rules have to
be inserted in which directory-tag (if they have to)?
3.) I do not exactly understand the splitup into three rules. I would be
very thankful for a short explanation of the logic here.
# Rewrite /wms/mapname to
qgis_mapserv.fcgi?map=/<path-to-qgis-server-projects>/mapname.qgs
RewriteRule ^/wms/(.+)$
/cgi-bin/qgis_mapserv.fcgi?map=/home/guna/www/test.de/projects/$1.qgs
[QSA,PT]
# Rewrite /maps/mapname to qgis-web-client main page. mapname will be
extracted for wms calls in Javascript code.
RewriteRule ^/maps/([^\.]+)$ /test.de/site/qgiswebclient.html [PT]
# Rewrite /maps/* to qgis-web-client/site (e.g.
/maps/gis_icons/mActionZoomNext.png ->
/qgis-web-client/site/gis_icons/mActionZoomNext.png)
RewriteRule ^/maps/(.*) /test.de/site/$1 [PT]
Thank you very much,
Gunnar
Gunnar Oehmichen
Quantitative Landscape Ecology
Institute for Environmental Sciences
University Koblenz-Landau
Fortstrasse 7
76829 Landau
Germany
http://www.uni-koblenz-landau.de/landau/fb7/umweltwissenschaften/landscape-ecology/Staff/gunnaroehmichen
