[Qgis-user] QGIS 2.2 - Remove layer dialog
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Feb 25 08:23:07 PST 2014
Hi List,
  QGIS 2.2 has a confirmation dialog when I go to remove a layer; Maybe
it's me but I'm sure the previous versions didn't - alternately I can't
find a setting anywhere to turn this behaviour off (I'm assuming I did in
the past if it was there).
Is this a new feature or have I just lost the setting? Personally I find it
quite annoying so would like to disable it.
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/d89252ff/attachment.html>
