[Qgis-user] Map Symbols?
Randal Hale
rjhale at northrivergeographic.com
Tue Feb 25 05:37:30 PST 2014
Mike - I'm assuming you are in the print composer portion of all of this:
if so:
1. Add your map to the print composer(white icon with a green + sign)
2. Add an image (should be the next icon just to the right - pic with a
green plus sign))
3. Click on item properties (just to the right).
4. Under search directories you should see a list of SVG images.
5. In there you will see some north arrows. It's a goal to make more
for QGIS - these lack soul.
6. Scroll down just a bit and you can check the box sync with map -
that will keep your image/north arrow aligned with the map if you
change it.
Randy
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
<mailto:rjhale at northrivergeographic.com>
twitter:rjhale
http://about.me/rjhale
On 02/24/2014 11:59 AM, Mike Keelan wrote:
> List,
> I simply want to indicate "North" on my map. It seems to me there
> should be a plugin with some standard symbols that can be scaled to
> maps in general? How are users handling this?
> Mike K
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/52673b5e/attachment.html>
