[Qgis-user] GRASS/SAGA in OSGeo4W - not loading
Victor Olaya volayaf at gmail.com
Tue Feb 25 05:49:52 PST 2014
i have just tried the osgeo4w installation, and I have seen that you
can install both SAGA 2.0.8 and SAGA 2.1.0. Make sure that the version
that you have selected to be installed, is the same one that is
configured for Processing. If you install 2.0.8, you should check the
"Enable SAGA 2.0.8 compatibility" in the Processing options
also, make sure that the path to SAGA is configured correctly. It
should be configured automatically, but only the first time that you
run QGIS and it is not configured. If it was already configured from a
previous insstallation, it will not adjust automatically to point to
that  C:\QGIS_2.2\apps\saga  folder in your system
I hope this helps.
2014-02-25 14:18 GMT+01:00 Jürgen E. <jef at norbit.de>:
> Hi Jonathan,
> On Tue, 25. Feb 2014 at 12:55:52 +0000, Jonathan Moules wrote:
>>   I was using the processing toolbox which is what gave me that. I'm not
>> sure what you mean by determining what dependency is missing. Or what
>> "internal tools" equates to.
> QGIS algorithms.
>> I'll wait for the full stand-alone install, but I can test the OSGeo4W one
>> if you want me to.
> The installer is made from the osgeo4w packages.  So testing the packages will
> also help the standalone version.  But the standalone installer is made from
> qgis-full.  So if installing all dependencies of qgis-full (the package itself
> contains no files) helps, the standalone installer should be fine too.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
