[Qgis-user] QGIS 2.2 - Remove layer dialog
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Feb 25 09:11:30 PST 2014
Hi Jürgen,
Thanks for the link.
>From attempting to read that:
- There's no way to turn it off. :-(
- Shortcuts must be used instead. :-(
- Delete or Backspace should delete a layer without asking for confirmation.
Is this correct?
Because if so, neither Delete nor Backspace works - they don't do anything
at all. Am I doing something wrong?
(Ctrl-D works - but that brings up the dialog... :-S )
Did I miss something or is this a bug?
Best,
Jonathan
On 25 February 2014 16:34, Jürgen E. <jef at norbit.de> wrote:
> Hi Jonathan,
> On Tue, 25. Feb 2014 at 16:23:07 +0000, Jonathan Moules wrote:
> >   QGIS 2.2 has a confirmation dialog when I go to remove a layer; Maybe
> > it's me but I'm sure the previous versions didn't - alternately I can't
> > find a setting anywhere to turn this behaviour off (I'm assuming I did in
> > the past if it was there).
> > Is this a new feature or have I just lost the setting? Personally I find
> it
> > quite annoying so would like to disable it.
> See #9094[1]
> Jürgen
> [1] http://hub.qgis.org/issues/9094
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/8c5bed6e/attachment.html>
