[Qgis-user] QGIS 2.2 - Remove layer dialog
Etienne Tourigny etourigny.dev at gmail.com
Tue Feb 25 09:24:23 PST 2014
I find it rather annoying also, and re-opened the bug.
On Tue, Feb 25, 2014 at 2:11 PM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Hi Jürgen,
> Thanks for the link.
> From attempting to read that:
> - There's no way to turn it off. :-(
> - Shortcuts must be used instead. :-(
> - Delete or Backspace should delete a layer without asking for
> confirmation.
> Is this correct?
> Because if so, neither Delete nor Backspace works - they don't do anything
> at all. Am I doing something wrong?
> (Ctrl-D works - but that brings up the dialog... :-S )
> Did I miss something or is this a bug?
> Best,
> Jonathan
> On 25 February 2014 16:34, Jürgen E. <jef at norbit.de> wrote:
>> Hi Jonathan,
>> On Tue, 25. Feb 2014 at 16:23:07 +0000, Jonathan Moules wrote:
>> >   QGIS 2.2 has a confirmation dialog when I go to remove a layer; Maybe
>> > it's me but I'm sure the previous versions didn't - alternately I can't
>> > find a setting anywhere to turn this behaviour off (I'm assuming I did
>> in
>> > the past if it was there).
>> > Is this a new feature or have I just lost the setting? Personally I
>> find it
>> > quite annoying so would like to disable it.
>> See #9094[1]
>> Jürgen
>> [1] http://hub.qgis.org/issues/9094
>> Jürgen E. Fischer         norBIT GmbH               Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
>> +49-4931-918175-50
>> Software Engineer         D-26506 Norden
>> http://www.norbit.de
>> QGIS PSC member (RM)      Germany                      IRC: jef on
>> FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/8855c3a8/attachment.html>
