[Qgis-user] QGIS 2.2 - Remove layer dialog
Richard Duivenvoorde rdmailings at duif.net
Tue Feb 25 12:57:13 PST 2014
Hi Etienne,
I'm fine with the solution of Jef: make it an option (now that it is done).
But in general: I do not like the fact that we had, I think, a
discussion of about 2 weeks with several people, which is thrown out of
the window because one reopens an issue and makes some noise. Apparently
the time we/I put into this discussion was not worth my time.
Besides this: I do not think having an option for everything is the best
option ;-)
Better to have a sensible default, have a discussion/voting and then
deal with that. An extra setting I see as a bad compromise here. The
Settings dialogs are getting more and more crowded with options I do
really not know anymore for which minimal detail it is giving me options
for.
Please let us create some (ui/hud) vision and hold on to that, so we are
not driving on user comments only.
Regards,
On 25-02-14 18:24, Etienne Tourigny wrote:
> I find it rather annoying also, and re-opened the bug.
> On Tue, Feb 25, 2014 at 2:11 PM, Jonathan Moules
> <jonathanmoules at warwickshire.gov.uk
> <mailto:jonathanmoules at warwickshire.gov.uk>> wrote:
>     Hi Jürgen,
>     Thanks for the link.
>     From attempting to read that:
>     - There's no way to turn it off. :-(
>     - Shortcuts must be used instead. :-(
>     - Delete or Backspace should delete a layer without asking for
>     confirmation.
>     Is this correct?
>     Because if so, neither Delete nor Backspace works - they don't do
>     anything at all. Am I doing something wrong?
>     (Ctrl-D works - but that brings up the dialog... :-S )
>     Did I miss something or is this a bug?
>     Best,
>     Jonathan
>     On 25 February 2014 16:34, Jürgen E. <jef at norbit.de
>     <mailto:jef at norbit.de>> wrote:
>         Hi Jonathan,
>         On Tue, 25. Feb 2014 at 16:23:07 +0000, Jonathan Moules wrote:
>         >   QGIS 2.2 has a confirmation dialog when I go to remove a
>         layer; Maybe
>         > it's me but I'm sure the previous versions didn't -
>         alternately I can't
>         > find a setting anywhere to turn this behaviour off (I'm
>         assuming I did in
>         > the past if it was there).
>         > Is this a new feature or have I just lost the setting?
>         Personally I find it
>         > quite annoying so would like to disable it.
>         See #9094[1]
>         Jürgen
>         [1] http://hub.qgis.org/issues/9094
>         Jürgen E. Fischer         norBIT GmbH               Tel.
>         +49-4931-918175-31
>         Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
>         +49-4931-918175-50
>         Software Engineer         D-26506 Norden
>         http://www.norbit.de
>         QGIS PSC member (RM)      Germany                      IRC: jef
>         on FreeNode
>         norBIT Gesellschaft fuer Unternehmensberatung und
>         Informationssysteme mbH
>         Rheinstrasse 13, 26506 Norden
>         GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>     This transmission is intended for the named addressee(s) only and
>     may contain sensitive or protectively marked material up to
>     RESTRICTED and should be handled accordingly. Unless you are the
>     named addressee (or authorised to receive it for the addressee) you
>     may not copy or use it, or disclose it to anyone else. If you have
>     received this transmission in error please notify the sender
>     immediately. All email traffic sent to or from us, including without
>     limitation all GCSX traffic, may be subject to recording and/or
>     monitoring in accordance with relevant legislation.
