[Qgis-user] QGIS 2.2 - Remove layer dialog
Andreas Neumann
a.neumann at carto.net
Tue Feb 25 10:56:34 PST 2014
We decided that for actions without an undo there needs to be a
confirmation. That's a common behaviour of most software.
Styling, filtering and assigning field widgets, etc. can be a lot of
work. If you accidentally delete the layer you better want a
confirmation to do so.
On the other hand we got rid of the confirmation for deleting features,
because there is an undo for this action.
Would there be an undo for deleting layers I would be fine to go without
the confirmation but not in the current situation.
Andreas
Am 25.02.2014 17:11, schrieb Jonathan Moules:
> Hi Jürgen,
> Thanks for the link.
> From attempting to read that:
> - There's no way to turn it off. :-(
> - Shortcuts must be used instead. :-(
> - Delete or Backspace should delete a layer without asking for confirmation.
> Is this correct?
> Because if so, neither Delete nor Backspace works - they don't do anything
> at all. Am I doing something wrong?
> (Ctrl-D works - but that brings up the dialog... :-S )
> Did I miss something or is this a bug?
> Best,
> Jonathan
> On 25 February 2014 16:34, Jürgen E. <jef at norbit.de> wrote:
>> Hi Jonathan,
>> On Tue, 25. Feb 2014 at 16:23:07 +0000, Jonathan Moules wrote:
>>> QGIS 2.2 has a confirmation dialog when I go to remove a layer; Maybe
>>> it's me but I'm sure the previous versions didn't - alternately I can't
>>> find a setting anywhere to turn this behaviour off (I'm assuming I did in
>>> the past if it was there).
>>> Is this a new feature or have I just lost the setting? Personally I find
>> it
>>> quite annoying so would like to disable it.
>> See #9094[1]
>> Jürgen
>> [1] http://hub.qgis.org/issues/9094
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden
>> http://www.norbit.de
>> QGIS PSC member (RM) Germany IRC: jef on FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
