[Qgis-user] QGIS 2.2 - Remove layer dialog
Etienne Tourigny
etourigny.dev at gmail.com
Tue Feb 25 14:01:51 PST 2014
Hi Richard,
I didn't want to throw away all that was done, I'm sorry if it sounded like
that. I reopened the ticket because a few people (including me) disagreed
with the change, and did not take part in the initial discussion.
I understand too many options are not a good thing, on the other hand
choice is good when it's not too confusing and easy to implement.
cheers,
Etienne
On Tue, Feb 25, 2014 at 5:57 PM, Richard Duivenvoorde
<rdmailings at duif.net>wrote:
> Hi Etienne,
> I'm fine with the solution of Jef: make it an option (now that it is done).
> But in general: I do not like the fact that we had, I think, a
> discussion of about 2 weeks with several people, which is thrown out of
> the window because one reopens an issue and makes some noise. Apparently
> the time we/I put into this discussion was not worth my time.
> Besides this: I do not think having an option for everything is the best
> option ;-)
> Better to have a sensible default, have a discussion/voting and then
> deal with that. An extra setting I see as a bad compromise here. The
> Settings dialogs are getting more and more crowded with options I do
> really not know anymore for which minimal detail it is giving me options
> for.
> Please let us create some (ui/hud) vision and hold on to that, so we are
> not driving on user comments only.
> Regards,
> On 25-02-14 18:24, Etienne Tourigny wrote:
> > I find it rather annoying also, and re-opened the bug.
> > On Tue, Feb 25, 2014 at 2:11 PM, Jonathan Moules
> > <jonathanmoules at warwickshire.gov.uk
> > <mailto:jonathanmoules at warwickshire.gov.uk>> wrote:
> > Hi Jürgen,
> > Thanks for the link.
> > From attempting to read that:
> > - There's no way to turn it off. :-(
> > - Shortcuts must be used instead. :-(
> > - Delete or Backspace should delete a layer without asking for
> > confirmation.
> > Is this correct?
> > Because if so, neither Delete nor Backspace works - they don't do
> > anything at all. Am I doing something wrong?
> > (Ctrl-D works - but that brings up the dialog... :-S )
> > Did I miss something or is this a bug?
> > Best,
> > Jonathan
> > On 25 February 2014 16:34, Jürgen E. <jef at norbit.de
> > <mailto:jef at norbit.de>> wrote:
> > Hi Jonathan,
> > On Tue, 25. Feb 2014 at 16:23:07 +0000, Jonathan Moules wrote:
> > > QGIS 2.2 has a confirmation dialog when I go to remove a
> > layer; Maybe
> > > it's me but I'm sure the previous versions didn't -
> > alternately I can't
> > > find a setting anywhere to turn this behaviour off (I'm
> > assuming I did in
> > > the past if it was there).
> > > Is this a new feature or have I just lost the setting?
> > Personally I find it
> > > quite annoying so would like to disable it.
> > See #9094[1]
> > Jürgen
> > [1] http://hub.qgis.org/issues/9094
> > Jürgen E. Fischer norBIT GmbH Tel.
> > +49-4931-918175-31
> > Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> > +49-4931-918175-50
> > Software Engineer D-26506 Norden
> > http://www.norbit.de
> > QGIS PSC member (RM) Germany IRC: jef
> > on FreeNode
> > norBIT Gesellschaft fuer Unternehmensberatung und
> > Informationssysteme mbH
> > Rheinstrasse 13, 26506 Norden
> > GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > This transmission is intended for the named addressee(s) only and
> > may contain sensitive or protectively marked material up to
> > RESTRICTED and should be handled accordingly. Unless you are the
> > named addressee (or authorised to receive it for the addressee) you
> > may not copy or use it, or disclose it to anyone else. If you have
> > received this transmission in error please notify the sender
> > immediately. All email traffic sent to or from us, including without
> > limitation all GCSX traffic, may be subject to recording and/or
> > monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140225/4036f486/attachment.html>
